radio antenna
I've sprung a leak and it looks to be coming in from the antenna mount. now the antenna that is there probably shouldnt be, and I'm looking at most of the major suppliers to get another. hopefully one that will fit. the LMC book scares me because it describes their antenna as a universal mount. I think thats my problem already. the orange truck and car shop antenna dont look bad. and ecklers looks like theirs is..I dont know I cant tell. anybody been through this?
Active Member
![]() Join Date: Jul 2007
Re: radio antenna
Where is the leak and where is the antenna mounted?
Water will enter into the cowl vent and if your antenna is missing like mine was, you will get moisture in there. Now if you have a leak coming inside the cab it may be from somewhere else. Some of the culprits are windshiled seal, rusted out or bad seal in drip channels or rust holes under the cowl vent. |
Re: radio antenna
the antenna is mounted on the passenger side fender, in what Im assuming is the factory hole. since the glove box is out, i can tell that the water is seeping through from where the antenna wire is coming. it probably needs sealing as well, but I'm wanting an antenna that will at least be sure and fit correctly, rather than some universal fit that will be questionable.
screamin eagle
Re: radio antenna
I just got one from brothers factory repro
SCREAMIN EAGLE |
Re: radio antenna
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Re: radio antenna
I dont believe the factory mounted antennas on the passenger fender. Im pretty sure they mounted them on the cowl on the passenger side.
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
Re: radio antenna
Active Member
Re: radio antenna
Antennas are factory mounted on the cowl on these trucks.
Here's two pics. The first is my 68 that came without the radio and the second is the 69 that had the radio option. That is the factory mounting location on the passenger side of the cowl. |
#9 | |
Re: radio antenna
http://www.classicparts.com/Radios/products/290/2/0
Active Member
Re: radio antenna
Forgot to add that I've read posts from others that have used the exact repro antennas and claim they are a good fit. There are other vendors that are members of this site and are great to work with. I always have trouble finding the place where they are listed, but it's in here somewhere. You can call them or email them also.
Re: radio antenna
Here is a list of the site vendors...the guys in gold/yellow.
http://67-72chevytrucks.com/vboard/showgroups.php
Re: radio antenna
I would contact a board vendor.. Tim Christian, pickupman, classic heartbeat etc... They are also truck owners and won't do you wrong... some of those shops don't know crap BTW... There is a small rubber grommet that seals that wire, I would remove the cowl and silicone the hole better...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#13 |
Re: radio antenna
i dont believe the factory ever mounted antenni if the truck had the radio option the anntennis were tossed into the front seat and were dealer installed
#14 |
screamin eagle
Re: radio antenna
SCREAMIN EAGLE |
