cab top same on 67-72?
I am looking for a cab top to chop off as a donr and put on my 72. Mine has rust around entire drip rail. My body man said he could cut the top off one and replace my top with that. I could go for a whole cab, but the rest of mine is perfect. Floor pan, roller, cab corners etc. Would any 67-72 top fit my truck? I would be cutting it from about the top of the front window all the way around. May even go down 5-6 inches and do the cuts.
#2 | |
Re: cab top same on 67-72?
They are making the outer roof skin for these trucks now. We sell them but you can get one at Goodmark since you in Ga Oh Yeah Same Last edited by mbgmike; 12-14-2009 at 08:51 PM. |
Yeah I have seen the outer roofs and would go that way, but I have rust through around drip rail and even makes it leak inside a bit. Some bubbles on inside, but nothing too bad. I want to cut the top to be sure I can get to and traet all the rust even down in the cab arms.
#4 | |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Yes. You can use a roof from a 67-72. They are all gonna be the same with the exception of the small window 67 cab.
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
Also mike thanks for the info. I did not mean to sound rude if it come across that way. I appreciate it guys.
check out my "flip that truck" build in my sig.. we did the same thing that you are talking about. some might have cargo lights above the back window and others might have raised pads for clearance lights but ours fit ok... have fun getting the front windshield back in...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Would any 57-72 top fit my truck?
57 might not fit to good. ![]() |
they are the same, but there are some variations allowed during assembly so make sure you fit the doors before fully welding back together
Mike Redpath |
