low n' slo
![]() Join Date: Mar 2009
What's this part called and where can i get it?
hey guys, i got this compressor off of another forum and it did not come with the black thing on the side. can anyone point me in the direction of where to get it and what its called? or could i just make something to cover it, im not sure if something goes in there or not...its an airlift 450c
[IMG] ![]()
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by smashingchuck; 12-15-2009 at 11:39 AM. |
Re: Waht's this part called and where can i get it?
That looks to me like someone put the filter directly onto the housing. On mine there's a fitting which I have a line coming off of and then that same filter(but w/ the rest of it) inside the cab to keep it out of water.
low n' slo
so there is supposed to be a hose coming from there? i was looking at a new 450c and this is what it looks like new..
![]() it kinda looks like a cap is missing or something, but im not sure if something goes inside there...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 12-15-2009 at 12:49 AM. |
A filter should go in there with a cover over it. My viair came with the tube that lets you move the filter housing to another location so water and junk stays out of it if its mounted to the frame.
low n' slo
do I have to run a filter in there, or can I just put a cover over it? and where could I get the part at?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
you need to run a filter . its works the same as the engine in your truck
the one from viair should fit
Epoxy Primer Friendly
Re: What's this part called and where can i get it?
You can buy the remote filter kits or replacements from Viair or one of there distributors local like Ekstensive. This is all the components a dual pack comes with new.
![]() Last edited by camaro__thunder; 12-15-2009 at 01:28 PM. |
low n' slo
ah ok, looks like im missing the black cap and the filter inside. is it ok to run it with the cap and filter if its in the framerail? or should i get the one with the hose and run it inside the truck?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 12-15-2009 at 03:45 PM. |
Bodydropped71
If i remember tomorrow ill check the shop for one. If i can find it your more then welcome to come pick it up!
low n' slo
ok cool, thanks
let me know if p8ntballer1911 cant find it and if not i will mail you my extra
#13 |
Happy to be here
![]() Join Date: Mar 2000
There is nothing wrong with mounting it inside, but according to RideTech it's not necessary. It does help if you remote mount it so it doesn't take so much abuse.
