Old 12-15-2009, 09:10 AM   #1
astevens
astevens's Avatar
rear sway bar installation
Does anybody have any info on installing a rear sway bar on a swb coil spring rear. I thought I ran across a website that gave the measurements, but I can't find it now. Thanks.
Aaron
astevens is offline   Reply With Quote
Old 12-15-2009, 09:34 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: rear sway bar installation
are you you installing the stock, pan hard bar or super track bar.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-15-2009, 12:02 PM   #3
cdowns
cdowns's Avatar
i've used the bolton helwig rear swaybar on two trucks with coil rears both were lowered4-5" the bar went on easy and worked great . i think i got them from jcwhitney
i liked it because it mounted ahead of the rear and clamped onto the trailing arms. which located the frame mounting points to the most rigid section of the frame with no panhard or gastank clearance issues as well as being tucked up out of sight
Old 12-15-2009, 12:59 PM   #4
myoldchevytruck
when i lowered mine, i replaced the stock springs for 6'' inch lowering springs from gmc paul's and used a super track bar from early classics (ece)
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 12-15-2009, 01:56 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
I called ECE (Early Classic Enterprises) about installing a rear sway bar and they advised me AGAINST doing this. I don't remember off the top of my head the reason though.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 12-15-2009, 02:15 PM   #6
astevens
astevens's Avatar
I lowered the rear with 4" drop springs and I have an adjustable panhard bar on it. I was wanting to mount the sway bar to the trailing arms.
Old 12-15-2009, 02:32 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Here you go:
http://www.classicperform.com/Instru...PDF/CP7401.htm
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 12-15-2009, 03:08 PM   #8
mrh33916
Project '67 454
mrh33916's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=334003
Check out this thread,
mrh33916 is offline   Reply With Quote
Old 12-15-2009, 05:18 PM   #9
astevens
astevens's Avatar
That's a big help. Thanks guys.
Aaron
Old 12-15-2009, 05:50 PM   #10
big_al_71
big_al_71's Avatar
Aaron
I had one on my truck when it was lowered four inches, when I went to six inch drop I was told that it was not reccomended to be used. I had the rr sway bar from CPP.
Here are some picts of it. Which one are you using?
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-15-2009, 06:02 PM   #11
astevens
astevens's Avatar
Big_al_71,
That's looks like the same one I have. I bought the bar and brackets that attach to the trailing arms at a swap meet. I need to make the brackets that mount to the sides of the frame. I also need to get the bushings. Why were you told it wasn't recommended when you dropped it more?
Old 12-15-2009, 07:18 PM   #12
OhOneWS6
OhOneWS6's Avatar
They told me the same thing. Basically said it makes the truck loose.
OhOneWS6 is offline   Reply With Quote
Old 12-15-2009, 08:46 PM   #13
LONGHAIR
The biggest issue with sway-bars is balance...and it's easy to get out of balance. The more "bar" you add the more intense things get...bumpy roads get worse.
In general, sway bars add traction to the opposite end of the vehicle from where they are mounted.
The main thing is "Be Careful"...test it in a safe area. I would expect it to "push" slightly more than before and then "snap" loose once the limit of the tire is reached....rather un-predictable.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-15-2009, 11:59 PM   #14
big_al_71
big_al_71's Avatar
Big_al_71,
I replaced my rear trailing arms with the square tubing ones from ECE my truck rides 100% better than it did before with the rear sway bar. I did not want to drill my new trailing arms so the sway bar was coming off no matter what wether they said yes or no..
Old 12-16-2009, 12:08 AM   #15
OhOneWS6
OhOneWS6's Avatar
That is the description ECE gave me. Sorry for leaving out the details.
Old 12-16-2009, 02:09 AM   #16
Joemomma1
Joemomma1's Avatar
When I went down there for a parts run today I asked him about this and he said the same thing. He said there was not enough weight back there for the need of a sway bar. He didnt say he was against the idea just thought it was overkill.
Im using one from a Trans Am, just flipped it over. I have'nt driven it yet so I can't tell you what kind of a difference it makes.
Joemomma1 is offline   Reply With Quote
Old 12-16-2009, 07:59 AM   #17
astevens
astevens's Avatar
How much of a difference does the rear sway bar make?
Old 12-16-2009, 09:32 AM   #18
suville
suville's Avatar
Anyone have thots on this setup? Looks like it would be a clean install altho not exactly bolt on. Im considering this on my burb but certainly open to input.
http://www.competitionengineering.co...?CatCode=13048
suville is offline   Reply With Quote
Old 12-16-2009, 10:28 AM   #19
OhOneWS6
OhOneWS6's Avatar
Nice install. I'd like to hear your reviews after you drive it. Don't forget to install the missing jam nut on your adjustable PHB.
Old 12-16-2009, 11:56 PM   #20
Joemomma1
Joemomma1's Avatar
Am I missing one? There's one there but you cant see it too good since its black.
Old 07-28-2010, 10:12 PM   #21
Strut
Strut's Avatar
Any update on the Trans Sway bar on the rear? How does it feel??
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 03-04-2013, 01:56 AM   #22
70blackfish
any updates???
OLD thread
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
