Old 12-15-2009, 07:54 PM   #1
mike16
pollution controls, how to run the hoses
I got a 72 307 half ton with 3 speed. Alot of whats under the hood is origional. I want to keep it that way. What about polution controls. Mine is not an CA truck. I got a switch on the tranny sid cover that I thought was for back up lites...wrong Huh? and the electrically operated air valve thingie that goes between the vac advance and the carb and som evap canister. Its all there but whats it do, how do you test it for correct opps and how do you route the hoses correctly and if need be where are new NOS parts available.
Expound please.
mike16 is offline   Reply With Quote
Old 12-15-2009, 08:09 PM   #2
john
member #16
john's Avatar
Re: pollution controls, how to run the hoses
Sounds lile you have TCS (transmission controlled spark) on your truck. The solenoid between the carb and vac advance allows advance only when in high gear. The trans switch controls it. It should also have a temp sender in the pass side head so it works only when up to oper. temp. Maybe someone has a vacuum diagram they can post.
john is offline   Reply With Quote
Old 12-16-2009, 12:30 AM   #3
mike16
My truck is not a ca truck, it would NOT have had the AIR system as well would it. It does not seem to have.
Old 12-16-2009, 12:51 PM   #4
toms68cst
toms68cst's Avatar
From what I've seen, non calf trucks with manual transmission trucks had AIR systems from 68 up. I'm not sure which year they went away from AIR though. My Non calf 68 still has AIR. I don't have anything on my tranny related to smog control though.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 12-16-2009, 01:34 PM   #5
cdowns
cdowns's Avatar
excellent diagrams of the charcoal recovery cannister routing are in the factory assembley manual most vendors can supply it for you at a reasonable price
Old 12-17-2009, 02:23 AM   #6
mike16
I'm fairly sure my truck did not have the AIR system on it. I got that factory assembly manual. but my truck is a 72 and there not alot on 72's in there or info on pulleys and brackets.
who has a parts manual for this 72 year truck? on Disk?
