Old 12-15-2009, 08:49 PM   #1
stevewhitmore
stevewhitmore's Avatar
Heater Core Blues (Inner fender well)
Trying to lower the inner fender well as advised in an previous call for help to lower it for a heater core install and all of the nuts are just spinning after having to use a breaker bar and a lot of swearing to get them loose at all.
Any idea's?
Steve
stevewhitmore is offline   Reply With Quote
Old 12-15-2009, 09:18 PM   #2
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: Heater Core Blues (Inner fender well)
I just did that with mine. I had to use a grinder with a flapper wheel to get the inner fender out. I just ground off the bolt heads.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-15-2009, 11:18 PM   #3
clay68c10
clay68c10's Avatar
Your captive nut fasteners are broken.
x2 on the cutting/grinding off heads
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-15-2009, 11:44 PM   #4
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Vise grip the captive nut fasteners and wrench the bolts. PB Blaster works wonders too.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 12-16-2009, 01:05 AM   #5
spyder4560
spyder4560's Avatar
Question Re: Heater Core Blues (Inner fender well)
I don't about everybody else's truck,but my 69 gmc 3/4 ton needed the heater core replaced and I just pulled the hood and the pass. side hood spring and walla,easy access to the heater core.Am I missing something?
spyder4560 is offline   Reply With Quote
Old 12-16-2009, 01:08 AM   #6
wancosc356
wancosc356's Avatar
I had to remove my hood, passenger hood hinge/spring, and inner fender to gain access to the screws holding the heater box onto the firewall. But I also didn't have a swivel attachment for my ratchet. Maybe that would make it possible. Not sure though.
Michael
Old 12-16-2009, 01:33 AM   #7
nickp51chevy
I did that for a little while but when I couldn't get a grip on the nuts I just got fed up and decided to grind the bolt heads off.
Had;
Old 12-16-2009, 01:39 AM   #8
wancosc356
wancosc356's Avatar
There ya go. Better off with new ones anyways. Glad you got it.
Michael
Old 12-16-2009, 07:46 PM   #9
292farmer
292farmer's Avatar
i drilled a hole big enough to get a tool through to get to the bottom bolts on the heater core box, had to wiggle a little to get out but it worked for me then rivited in two patches for the holes i drilled, i used a flexible socket extension to fit in the hole and to help manuveur, just my idea u may want to keep your fender unmolested so maybe not the idea for u
292farmer is offline   Reply With Quote
Old 12-16-2009, 09:40 PM   #10
chevygrl68
i did a heater core in my 68 two weeks ago - exactly this way... took off the passenger side hood hinge and spring - gave me just enough room to do the work
chevygrl68 is offline   Reply With Quote
Old 12-17-2009, 01:46 AM   #11
aggieguy713
aggieguy713's Avatar
i did one on my 70 a few weeks back also. The way i did it was i just cut the box yes cut the box, made sure the core was stable enough, then just took a peice of tin metal, and fabbed it to the front where i cut it. looks real nice with the rest of the crome inside
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 12-17-2009, 11:17 AM   #12
69GMCLonghorn
69GMCLonghorn's Avatar
You need to check out a website called www.thereIfixedit.com That's all I'm going to say. Just check it out...
69GMCLonghorn is offline   Reply With Quote
Old 12-17-2009, 12:33 PM   #13
snowblind
snowblind's Avatar
My truck has the same modification courtesy of the PO!
It's actually a pretty clean way to do it. My PO cut it right down the axis of the holes for the heater core hoses. He did a really clean cut and then siliconed it up on reassembly. It probably seals better than leaving out the bottom bolt when reassembling...
Matt
'72 Jimmy Build
snowblind is offline   Reply With Quote
Old 12-17-2009, 05:14 PM   #14
aggieguy713
It dosent look bad, if it wasnt raining here id take some pics and post em up, just didnt have the time to take off the quarter pannel and inner fender, so i fabbed a quick fix.
