Old 01-23-2003, 11:50 PM   #1
minibike
minibike's Avatar
Brake bleeding question
When bleeding brakes, what needs to be done to the proportioning valve? There is a little pin in the end of it that I have heard has to be pushed in or something...is this true? I have 71 discs/master cylinder/proportioning valve.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 01-24-2003, 12:28 AM   #2
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I've never done anything special and it always works fine. Now, if I could just get the rears to stop locking...(90 wt in drums)
-Jesse
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 01-24-2003, 12:33 AM   #3
Low68
Low68's Avatar
I have never heard anything about that. You are talking about the stock type (non adjustable) right? If it is stock, I don't think you have to do anything special.
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 01-24-2003, 01:43 AM   #4
MR. GOODWRENCH
MR. GOODWRENCH's Avatar
you do nothing to the proportioning valve,it is factory preset,make sure the matercylinder is full and the lid clipped on,get someone to pump the brake petal 6 or 7 times,and on the last pump hold the petal to the floor,someone else needs to loosen the bleeder screw on the caliper and let the air out,but do not let off the brake petal until the bleeder screw is tightened or it will suck in air,do this until you get a steady stream of brake fliud out of the bleeder screw,do the same on the back wheelcylinders,and your done,it may sound hard from what I have wrote here,but it is a very easy job to do.
68 CST SWB,full off frame restoration,72 GMC Sierra Grande SWB,72 Cheyenne 30 long wheelbase flatbed,2000 4door Chevy Dually bought new,2002 SS Camaro with 600 miles,bought it to put up,72 Monte Carlo,it was my first car,69 Impala with 50,000 miles,it was my dads,89 Dodge diseal 3/4 ton 4 wheel drive,my dad bought it new,68 Camaro RS dragcar,97 United Transporters 25 foot enclosed trailer,58 Oliver Super 77 Diseal,my grandfather bought new fully restored,55 Oliver Super 66 Diseal my uncle bought new,49 Oliver Rowcrop 88,51 Farmall H,51 Farmall Super C,81 Ford 3600,89 Ford 6610,49 Allis Chalmers WD45,81 Allis Chalmers 7060 my dad bought new,Allis Chalmers 175.
MR. GOODWRENCH is offline   Reply With Quote
Old 01-24-2003, 03:17 AM   #5
Hooter
My other Love
Hooter's Avatar
I never had to do anything with the proportioning valev when I bleed brakes. I know what you are talking about my factory service manual shows the same thing for my Monte
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-24-2003, 09:12 AM   #6
minibike
minibike's Avatar
Thanks guys...I have all new lines, wheel cylinders, calipers and master cylinder. I have been getting a lot of air out of it, but I guess it is to be expected. I'll just keep bleeding...
69 SWB
LT1/4L60E
Old 01-24-2003, 12:20 PM   #7
cacauba
STL-KKN
cacauba's Avatar
go to the parts store, i got mine from NAPA. there called speedbleeders. they are about 10.00 for a pair and they have a check valve in them. they replace the bleeder screw in the wheel cylinder. they work awsome for one man operations.
chris
1969 C10 350/POWERGLIDE
1991 1500 EXTCAB 350
Formally: collegeK5er
cacauba is offline   Reply With Quote
Old 01-24-2003, 01:12 PM   #8
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
It is not too necasary, but did you bench bleed the master cylinder????I did and it helped a bit!! But when I did that I had very bad dirty brake lines and clogged front hoses so I never got to bleed them correctly my self.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 01-24-2003, 03:47 PM   #9
Stout72
Not my good side.
Stout72's Avatar
Bench bleeding the master cylinder is real important. It saves you from continuing to pump air thru the system. I had a problem with mine, I didn't bench bleed it enough so I just couldn't get rid of the air. Bench bled it again and I finally got straight fluid.
As for the prop valve, the book says you have to depress the pin on the end of it to properly bleed the back brakes, and to bleed the back brakes first. Mine wouldn't depress, so I just bled them in order from furthest to closest to the master cyl. Seemed to work for me.
Good luck!
Hey, this is my 100th post! Finally!
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 01-24-2003, 08:12 PM   #10
minibike
minibike's Avatar
Thanks guys...in my haste, I did not bench bleed the master cylinder. Pretty stupid. It's time to slow down and take a deep breath. This is the most important system on the truck, and I rushed it...
69 SWB
LT1/4L60E
Old 01-25-2003, 12:24 PM   #11
Oborny71
Oborny71's Avatar
Yeah like mentioned before, make sure you start with the farthest wheel away from the master cylinder ( the right rear) and work to the closest ( the left front)
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
