Old 12-15-2009, 11:18 PM   #1
oldno7
oldno7's Avatar
drop spindle ?
So afew years back I purchased a set of early classic drop spindles. I know they require disk brakes, and thinking I need to run the 5x5 bolt circle rotor. So does anyone have a 4 3/4 rotor that will fit my spindle's. Or does anyone have a drop spindle that uses 4 3/4 setup for these truck's. I would like to have more choices when it comes to my rims as their are more 4 3/4 than 5x5. Also what is the proper way to measure the spindle. Thanks in advance oldno7
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 12-16-2009, 03:12 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: drop spindle ?
POL (PerformanceOnLine) sells a rotor that has the 4-3/4" bolt circle.
If you have ECE spindles they will work with the rotors.
The only ones that won't work the OEM stock spindles for the 1" wide rotors.
Give these guys a call:
www.performanceonline.com
Keith
Convert to disc brakes.
Old 12-16-2009, 03:14 PM   #3
lolife99
lolife99's Avatar
Re: drop spindle ?
Also,... if you convert the front to 4-3/4" BC,... what are you planning to do with the rearend?
Keith
Old 12-17-2009, 08:46 AM   #4
oldno7
oldno7's Avatar
Re: drop spindle ?
The rearend will be replaced with a dana 60 4 3/4 bolt circle I like the lowered look, but im not going to lay frame. I'm planning on having some power under the hood and want to make sure the rearend stay's put. I want to have some meats under the back 17x11 or 18x12, but trying to figure out what tire wheel combo is difficult then the whole bolt circle thing doesn't help. Well thanks and im going to check into performance online oldno7
oldno7
