Closed Thread
Old 12-15-2009, 11:37 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Will a 5 Speed that came in 81 fullsize Fit to a 6.2 Diesel?
I have this overdrive Tranny that was original to a 81 Fullsize Chevy Truck, Trying to Sell it on my Local CL & Got an Inquiry if it would work with a 6.2 Diesel Engine ???
Was a 6 cyl Truck if that would
matter, What do u Guy's Think? Will it work for his 6.2? Thanks for any Info ...........
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline
Old 12-15-2009, 11:50 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Will a 5 Speed that came in 81 fullsize Fit to a 6.2 Diesel?
That pic of the shift knob is only a 4 spd...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline
Old 12-16-2009, 12:00 AM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Yeah, its a 4-speed OD. With the right bellhousing and input shaft it should work. Call Advanced Adapters after you get numbers off the tranny. Tell em the number, they should be able to hook you up, or know who can hook you up. No pun intended.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline
Old 12-16-2009, 12:04 AM   #4
Russell
Professional Grade
Russell's Avatar
Yup, it'll bolt right on and use the same clutch as an SM465 equipped 6.2L would (factory trans used behind the diesels).
However, I doubt that one of those little A883s would be up to handling the torque generated by anything bigger than the 305 it was probably behind from the factory
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline
Old 12-16-2009, 12:06 AM   #5
toomanytoyz
Luv the Crewcabs
Take a Closer look at Middle Pic, Shows 4th has OD......
I drove the Truck Till Motor went Klaplueeeeeeee
WAs Nice having a 5 Speed.......
thirdstreettito, I knew you would Prolly know the answer & Almost just pm-ed you about it. Then i thought that the knowledge would be Good for the Board & Posted it .......
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-16-2009, 01:27 AM   #6
hatzie
Moderator
hatzie's Avatar
I wouldn't be that quick to discount the A833 OD. They are pretty tough. When I was much younger I beat the hell out of one behind a built 383 in a rusted out '68 Fury. Chrysler put em behind 440s too.
The A833 countershafts can and do spin and wallow out the case behind the bellhousing. If it leaks oil from the countershaft bore you'll need to bore and bush the case.
hatzie is offline
Old 12-16-2009, 01:29 AM   #7
2tons of fun
how is it a 5speed again???
1 2 3 od, it r 4spd.
2tons of fun is offline
Old 12-16-2009, 01:45 AM   #8
thirdstreettito
Resident of Here
Thanks, Rick
~Bradley~
Miss having a truck
Old 12-16-2009, 08:29 AM   #9
6977chev
6977chev-Please don't turn this in to a "For Sale" post.
6977chev is offline
Old 12-16-2009, 09:40 AM   #10
Russell
Professional Grade
Russell's Avatar
Unfortunately, these are nothing like their older Chrysler counterparts. Those tough transmissions have a cast iron housing, and a totally different gearset inside which make them capable of standing up to the old 440s and such. The version GM used is really watered down, and is only rate for something like 275 ft lbs of torque IIRC
Russell is offline
Old 12-16-2009, 09:55 AM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Here is some good info on them:
http://www.customclassictrucks.com/t...ion/index.html
I agree that it is a 4 speed, not a 5 speed.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline
Old 12-16-2009, 07:46 PM   #12
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
I looked at a 82 1/2 ton 4x4 last year that had that trans behind a 6.2 from the factory. I was going to buy it and put another body on it because it had been rolled. The old guy who owned it had owned it since 1984 and said that truck would get 22mpg. I really wanted to buy it but he wanted WAY to much for a truck that was going to need a total body swap.
BIGCHEVYMAN is offline
Old 12-16-2009, 11:46 PM   #13
72 CustomCamper
huh ???
Found this on the net.
"The Overdrive four speed was a regular A-833 with an overdriven gear set installed in place of the regular third gear. The shift lever on the side cover was flipped over to "fool" the shifter into shifting from second to fourth and then back into third, which was the overdrive gear. The overdrive gear is very small and as a result, the mainshaft journal and splined hub is smaller. You can swap OD 833 parts as a set into the correct case for the mainshaft."
Old 12-16-2009, 11:51 PM   #14
Stitch
Location: Where I come from, it's cornbread and chicken...
4 forward gears and 1 reverse = 5 gears...
don't you guys know anything...
Stitch is offline
Old 12-17-2009, 01:22 AM   #15
Stitch
btw Rick, just to clarify, I was kidding....not trying to rattle any chains...just a joke...I know that wasn't directed toward me, but thought I would clarify...
Stitch is offline
Old 12-17-2009, 01:32 AM   #16
toomanytoyz
Luv the Crewcabs
No Problem, Sorry if i came across Wrong..........
Just kinda Upsets me when Stuff like this Happens, I Don't expect to see this Here. I feel that for the most Part members here are Above this petty Bickering...........
Any more of it & I will ask that the Thread be deleted, In that case we alll lose as some Good info was Posted.
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-17-2009, 01:35 AM   #17
Stitch
yeah like I said, I'm sorry for it...I kinda got carried away with the joking around and thought I'd add my 2 cents...
Stitch is offline
Old 12-17-2009, 01:48 AM   #18
joe231
joe231's Avatar
Rick, not to beat a dead horse, but I don't understand how it is a 5 speed?
First, second, third, and overdrive is 4 speeds, where does the fifth gear come in? Does it have a solenoid in the trans to engage overdrive?
Seems like this would be a cool trans in a daily driver for some decent mileage.....
CHEVY ONLY
joe231 is offline
Old 12-17-2009, 01:55 AM   #19
Stitch
Joe I think this is how it works
Stitch is offline
Old 12-17-2009, 02:11 AM   #20
2tons of fun
its still a 4spd,
you have to flip a lever on the side cover, are you going to do that at speed?
when the lever is flipped it swap the shift pattern in a way that doesnt make sence but is not something that i would think is possible to do while driving.
Old 12-17-2009, 02:14 AM   #21
Stitch
either way, it does still have 5 forward gear speeds...
it's really starting to split hairs now...he only asked if it would fit behind a 6.2...that question has already been answered...
now it's just arguing to argue...I'm done with it...
Stitch is offline
Old 12-17-2009, 03:36 AM   #22
toomanytoyz
Luv the Crewcabs
Could a Mod Please Just Lock this Thread , Apparently owning, Driving, shifting this Transmission is not enough Proof that it Has 5 forward Gears.......
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-17-2009, 09:21 AM   #23
joe231
joe231's Avatar
I don't understand why everyone is getting bent out of shape?
Rick, I'm not doubting you, I'm just trying to understand how it has 5 speeds when the shifter knob, and the link posted with info about it, only shows 4 forward gears.
The text Fat Hoe quoted only describes how the shifter is set up to work, it doesn't explain how there are 5 forward gears....
It basically says that 3rd and 4th gear are flip flopped and what was 4th gear(1:1 ratio) becomes 3rd, and what was 3rd becomes OD(with a new gear set of .73:1)
CHEVY ONLY
joe231 is offline
Closed Thread
