Old 12-16-2009, 07:47 AM   #1
KrazyKevin
What have I gotten into
KrazyKevin's Avatar
Upper A-arm studs...
After taking the front end apart, I got to the upper A arms. There are two studs per side. They appear to be pressed into the frame. 3 of the 4 are solid. But the front bolt on the drivers side has some play in it. It doesn't spin in the hole. I was able to take the nut off without it spinning. But, since some of the shims had came out of place, there wasn't alot of tension on it. So, should I worry about this? Or will it tighten up when I reinstall everything? It is not wollered(sp?)out, just has a lil wiggle to it.
Lastly, and excuse my ignorance for not knowing exactly what to call this, but the big nuts that cap the end of each upper and lower A arm pins? The threads on the inside that actually screw onto the bar/pin are fine. But the outter threads that screw into the actual A arm themselves seem shallow. They almost seem gaulded, but all eight of them are the same way. I cleaned the threads best I could before unscrewing them. Is this how they look? Or, are mine screwed? Sorry for the pun, but its late.
Thanks guys
Kevin
1972 Chevy SWB Fleetside
Project BumbleBee
KrazyKevin is offline   Reply With Quote
Old 12-16-2009, 01:28 PM   #2
Wrenchbender Ret
Re: Upper A-arm studs...
Usually if a bolt is loose in the crossmember it will turn. You can use it this way but it makes it hard to do an alignment if it turns.
Those treads are shallow. They usually tighten down good but if not I have welded the cap to the arm. Keep the shaft in the center as you tighten the caps & make shure it is centered before you put it on.
Wrenchbender Ret is offline   Reply With Quote
Old 12-16-2009, 04:23 PM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I would go ahead and repalce them, ECE carries them in stock
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-16-2009, 05:34 PM   #4
71tahoe
71tahoe's Avatar
It was probably more like there wasn't as much tension on it so some of the shims came out. The new one you replace it with might be loose too if the hole is elongated. I don't really have a new suggestion for a solution, just that new studs might not solve the problem.
71tahoe is offline   Reply With Quote
Old 12-16-2009, 08:20 PM   #5
57larry
would it be better to swap in newer A arms like from a 84?
57larry is offline   Reply With Quote
Old 12-16-2009, 08:23 PM   #6
KrazyKevin
KrazyKevin's Avatar
If the hole is elongated, what the next option, weld the hole up and redrill or tack/weld the stud in place?
Project BumbleBee
