Old 12-16-2009, 04:24 PM   #1
munger
munger's Avatar
what year did they change the 4wd pumpkin over to the left
mitch
87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s
munger is offline   Reply With Quote
Old 12-16-2009, 06:09 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: what year did they change the 4wd pumpkin over to the left
When the trucks where changed to Independent Front Suspension on the 1988 K trucks. GM didn’t offer a left hand pumpkin on any solid front axles that I am aware of.
DirtyLarry is offline   Reply With Quote
Old 12-16-2009, 11:30 PM   #3
nekkidhillbilly
hes right
nekkidhillbilly is offline   Reply With Quote
Old 12-17-2009, 12:00 AM   #4
munger
munger's Avatar
But a np231 tc is a driver side drop
mitch
Old 12-17-2009, 12:08 AM   #5
oats84
oats84's Avatar
IFS trucks
1989 jimmy "U.A.V"
44/14blt 4.56s locked up
37's
1984 2wd swb
1969 swb 4x4
oats84 is offline   Reply With Quote
Old 12-17-2009, 12:09 AM   #6
2tons of fun
yeah. so is the diff in any truck that would have a 231, and the only trucks to get 231s were ifs.
2tons of fun is offline   Reply With Quote
Old 12-17-2009, 12:24 AM   #7
munger
munger's Avatar
Then on a 90 chevy with a 700r4/np241 the drop is on the passenger side
mitch
Old 12-17-2009, 12:43 AM   #8
2tons of fun
is it a solid axle truck? ie blazer crewcab or sub?
Old 12-17-2009, 11:22 AM   #9
munger
munger's Avatar
No its just a half ton rclb
mitch
Old 12-17-2009, 11:23 AM   #10
munger
munger's Avatar
But i want to find a 241 that us passenger drop for my 87 then ill have a bulletbroof drivetrain tbi 5.7 700r4/np241
mitch
Old 12-17-2009, 12:29 PM   #11
Tony@AirRideTech
Junior Member
find one out of a 88-91 Suburban, full size blazer or Crew Cab.
Tony@AirRideTech is offline   Reply With Quote
Old 12-17-2009, 01:18 PM   #12
Jonboy
Slots go on anything!
Wasn't the 241 case (with pass. drop) only in the trucks with the electric speedometer- the 90-91 V series trucks? I thought is was similar to the 208, but did not have a speedometer gear drive, just the provision for the electric speedo.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-17-2009, 02:14 PM   #13
Tony@AirRideTech
Junior Member
Good question.... you got me there.... My 90 Burban has one but to be honest Ive never looked to see if the speedo was electric or cable.....
Old 12-17-2009, 02:50 PM   #14
Thealien
Thealien's Avatar
There are speedo solutions either way
Old 12-17-2009, 03:16 PM   #15
Tony@AirRideTech
Junior Member
yes... there are ... you can get electronic cable speedo drives.
Old 12-17-2009, 04:09 PM   #16
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
1989 was mechancial speedo 241, if from a blazer suburban crew cab or cab and chasis (ive seen older body style cab and chasis's) then it would be a passenger side drop. the 90-91s were electric speedo.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-17-2009, 09:04 PM   #17
b454rat
I know for a fact that 91 was the only year 205 had the VSS. 90 was a cable. I think the 241 got the electric VSS in 90 and 91.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 12-18-2009, 12:16 PM   #18
LONGHAIR
So what would be wrong with using a Ford front axle? The straight axle trucks, before '80, had driver's side differentials.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-19-2009, 12:46 AM   #19
munger
munger's Avatar
its a ford axle that would fail after 1/2 mile
mitch
Old 12-19-2009, 01:06 AM   #20
Walts_restoration
lots of guys use the dana 60 high pinions from the fords when they solid axle swap the new ifs rigs.
Old 12-19-2009, 01:10 AM   #21
munger
munger's Avatar
but i dont want a big project just a drop in and go
mitch
Old 12-19-2009, 01:22 AM   #22
Walts_restoration
Your 87 already have a 4x4 trans?
Your tbi might run off of the speedo cable. Mechanical cable. So find an np208 or a 1989 241 t case (rare) with mechanical speedo and go.
Get a passenger side pumpkin 10 bolt, dana 44, dana 60 would be the most (6 lug) and 3/4 (8 lug) configurations.
Is your truck already a 4x4? or are you converting?
As to the 231c, avoid it like the plague.
Old 12-19-2009, 01:54 AM   #23
munger
munger's Avatar
yea it has a th350 and a np203 for some odd reason but the th350 is out so i was thinking a 4 speed np205 swap or a 700r4 np 208 or 241 swap probly easier
mitch
Old 12-19-2009, 02:50 AM   #24
Walts_restoration
th350 203 would not have been stock. last th350 was iirc 85. Id look for a mid 80s 465/205 combo because they would be fine spline as opposed to the 70s trucks. Your current axle should be fine. Just need a new driveshaft front and rear, or yours lengthened/shortened as needed.
And dont forget, the parts needed from auto to manual swap, whether your going mechanical or hydrolic clutch. its easy, lots of guys have done it, just need the right parts, research first collect parts then do the swap.
Old 12-19-2009, 09:20 AM   #25
b454rat
I used to hear this alot and have to laugh. They are made my Dana, only thing that is Ford is some of the brake pieces. Can't remember which part. They did do some goofy stuff, but for the most part Dana 44's are the same.
If you wanted a drop in axle driver drop, the closest would be a 78/79 3/4 ton with the 8 lugs, or a 1/2 ton extended cab. They are basically a 3/4 ton axle but with 5 lugs.
Then just swap out the outers for 6 lug.
And I used HP60s in a couple of my trucks, one that is in my sig. Would rather use one of these or HP44 than a GM 44.
