NP203 question
Hey gang, on my '76 GMC k15 I was wondering if I put a np203 w/o the
Mile Marker kit in the tcase, can I leave the Mile Marker lock out hubs on the front wheels and just leave the hubs locked in all the time or do I need to remove the lock outs? Basically I want to know if it will work w/o removing the lock out hubs. |
#2 | |
Re: NP203 question
Yes it will work with the hubs locked-in.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Watchin the rust grow
![]() Join Date: Oct 2008
Re: NP203 question
With the hubs un-locked in the "free" posistion, the driveshaft will be spinning (front and rear) but it will not be putting the power to the ground. I think. I also believe this is very hard on the transfer-case. Am I right?
Until you actually part-time the t-case (if you plan to) I'd just leave 'em locked in and let the good times roll.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
Re: NP203 question
Thanks, keep the info coming. Always feeding on good advice.
Junior Member
Re: NP203 question
not to be a nay sayer but what is the point of keeping a 203 in there with manual lockouts, without the planetary grear change-out? If it is because you have grenaded a set of factory automatics, I would go ahead and change it all over. better mileage and the truck will drive better. If it were me, I would swap out for a 208 / 241 style case. Has a better low range and if you keep them serviced they are excellent cases.
#6 | |
Re: NP203 question
While I would totally agree with doing the entire installation....automatic hubs did not come with NP203 transfer cases. They had solid slugs that were splined inside and out.....automatics came with NP208 'cases starting in the early 80's.
#7 | |
Re: NP203 question
only the front shaft will spin because the shafts are disconnected, but you wont move. |
Re: NP203 question
The np203 is a full time case, so the front and rear drive shafts are always engaged, unless the transfer case is in neutral. Then neither will spin.
I can still count my vehicles on two... wait three hands. |
![]() Join Date: Oct 2006
Re: NP203 question
The 203 is full time but it has a set of spider gears in the rear of the case to transfer back and forth to front and rear when in the 2H or 2L position. Therefore with the hubs unlocked it takes the path of least resistance to the front driveshaft and leaves you sitting still. I think I explained it right??
IF A FELLA DOESN'T USE HIS HEAD....... HE MIGHT AS WELL HAVE TWO BUTTS ![]() 1969 C10 LWB "Granpaps Truck" (Project) 2000 K3500 Crew Cab LWB (Farm Truck) 2007 Chevy 1500 Crew Cab 5.3 (Daily Driver) |
#10 | |
Junior Member
Re: NP203 question
Good explanation....... NP203= Boat anchor ![]() |
#11 | |
Re: NP203 question
yeah, basically it is another open differential between the front and rear drive shafts.
with the manual hubs on the front unlocked, the front shaft will spin and the rear will do nothing, just like in an open diff with one tire off the ground.
![]() ![]() Last edited by joe231; 12-18-2009 at 12:30 PM. |
Re: NP203 question
Depending on what you use the truck for. I have one in a 78 3/4 ton that has never been converted. I use it around the farm, no highway driving to speak of, and I love it. 95% of the time The full time does good enough I don't even shift into 4wd. Otherwise you are right.
#13 |
Re: NP203 question
yes it its, but with the front hubs unlocked all the power will go to the front shaft because it is free and the rear shaft is locked. just like a onpe diff, one whheel spins and the other stays put because it has the traction.
#14 |
Re: NP203 question
Apparently I miss read something. My Blazer still has the full time np203, and I've never had a problem with it. I like it. Mileage sucks, but I drove an '86 Sub with a np208 that got the same mileage.
#15 |
Re: NP203 question
my 77 has the same t-case. i took out the front left gear thats in the hub, it goes into 2wd. BUT you have to pull the lever all the way back into 4loc or else it does nothing. and as far as milage, it makes NO difference, believe me
77 chevy k10 Bonanza-Restored when i was 17 76 chevy c10 short box-scrapped 81 chevy c10 silverado short box-project 64 impala 2 dr hard top-project waiting to get started |
#16 |
Re: NP203 question
I gained about 1.5-2 MPG when I part-timed and put hubs into mine.
Of course, it depends on how and where you drive. I think if your constantly gunning or tossing mud around then you're not going to notice any difference in mileage.
