Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-16-2009, 10:42 PM   #1
MJN
MJN's Avatar
block heater question
I got a '98 Jimmy with a factory installed block heater. We bought the truck used and I know the block heater was used by the previous owner. It's on a timer to come on for two hours before going out to start the truck in the morning. My question is when the heater is plugged on, will the coolant temp register on the gauge? And what temp will it heat it to?
I know some diesel engine block heaters keep the engine around 110 degrees. The factory shop manual doesn't say much other than how to install one, nothing specific about it otherwise.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 12-16-2009, 11:33 PM   #2
shadetree
shadetree's Avatar
Re: block heater question
Your stock gauge will show the temp when the key is on, and no 2 heaters will heat an engine to the same temp.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 12-17-2009, 08:06 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
it wont get it warm enough to show on the gauge. IIRC a 400 watt will raise it 70*
68C15 is offline   Reply With Quote
