Old 12-16-2009, 11:37 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
12 bolt posi rebuild
Is it possible and financially feasible to rebuild a 12 bolt that is currently open to a posi or locked rear end?
Just trying to plan how to spend money I don't have just yet
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 12-17-2009, 09:33 AM   #2
chrismoore701
chrismoore701's Avatar
Re: 12 bolt posi rebuild
I planned to do this and found out it will take about $400 doing it yourself or $800 to have it done. So I am thinking of waiting until later for mine.
Chris
chrismoore701 is offline   Reply With Quote
Old 12-17-2009, 12:33 PM   #3
Tony@AirRideTech
Junior Member
when it comes to axles dont go cheap. You dont want to rebuild it again because of inferior junk. You looking at the difference between a couple hundred bucks. A good Eaton pro Posi will run you around 400. new bearings and seals... around 60-80 bucks, new Gear set... 150-200. if you have never set up a GM axle i would not experiment with new stuff. Especially if you dont have the right tools. Pay someone a hundred bucks or so to come over and show you how.
Tony@AirRideTech is offline   Reply With Quote
