Old 01-24-2003, 01:32 AM   #1
Tuffold72
Camaro tach, ???
What all is involved with swapping in a 70's camaro tach into a factory 68 dash?
Tuffold72 is offline   Reply With Quote
Old 01-24-2003, 03:28 AM   #2
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Pretty easy with the thirdgen, here is 84 camaro guages in my '68, temp, gen, fuel above radio in mne.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 01-24-2003, 02:59 PM   #3
Tuffold72
That looks pretty cool! But I am looking for info on putting a mid 70's tach in the center hole were the factory one would have been. Thanks again!
Old 01-24-2003, 03:38 PM   #4
71Chev
71Chev's Avatar
The following instructions are from (user) Original69.
Z28 Tach in a 67-72 truck.
Parts needed are the tach, at least 8ft wire. Crimp on ends, 6 nuts same size as the z28
guage studs, grommet, plastic cleaner, drill bit etc. I’m sure I missed something..
Here is an overveiw of the tach install. I used a tach from a 79 Z28 cluster.
1-Dissasemble the rear cover by removing the screws on the edge. I think
there are 8 of them . Set it aside.
2-Take out the black metal plate and set it aside.
3-Take the plastic plate out and you will need to remove the lines in white
that are there. I used a Meguires plastic cleaner and a whole lot of rubbing.
Be careful not to remove any of the other white lines, only the ones where
The tach is going.
4-Get the metal plate, the one with the black side and you will need to
remove the area where the tach will be. I removed just the circle area to
the edge. The tach circumference should be about ½' larger than the circle you are cutting out.
Go slow here and do a good job
5-You will have to trim off the small tab on the tach where it sticks out.
Don’t worry about the small notch that’s there, you won’t see it when
It’s done. I did cut two small pieces off of the edge for the dash lites to
Show thru at night. About ¼'
6-Put the tach where it goes. I had the bend the bottom and top edges with
small pliers before it would fit.
7-Take the tach back out and you will have to do some work to it now.
8-The tach has 3 studs coming thru an insulator plate. This will have to be
removed. I took the 3 nuts and insulator off marking on paper where
wires went. (grnd, pos, tach). You will have to screw the 2 small nuts
on the studs one at a time to DOUBLE NUT them before you cut them.
I used a cutoff wheel and cut close to the top nut. Then back one nut off
and when you do all three hook the three new wires onto the shortened studs.
9-Put the tach back into the cluster and turn it around finding the
best fit in the front. I used sheet metal screws to hold it in. You
can drill a small hole then screw the sheet metal screws in close
along side the tach. This will not show in the front and is good enough
to hold the tach from moving.
10-Now take the rear metal piece and figure out where the tach screws
could possibly hit. It is very close here. If you need room take the
plastic circuit piece off, then use a small ball peen hammer and
hit it a few times to bulge it out some. Be careful you don’t hit
it out too far as the circuit plastic might not want to go back on.
Mine is very tight but I needed the clearance inside.
11-Drill a small hole big enough for the 3 wires and a rubber grommet
to pass thru the rear plate.
12-Check everything before you screw it all back together to make sure.
I also put a few pieces of electrical tape where the studs might hit the
inside of the rear plate.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 01-24-2003, 07:16 PM   #5
Tuffold72
Thats what I was looking for! Thanks, do you have a pic of the completed setup?
Old 10-08-2004, 01:58 PM   #6
71Chev
71Chev's Avatar
Old 10-08-2004, 05:37 PM   #7
me3
hart
where do the turn signal lights and the others go?
me3 is offline   Reply With Quote
Old 10-08-2004, 05:44 PM   #8
71Chev
71Chev's Avatar
In a factory non tach dash, there is nothing in the center hole.
Old 10-08-2004, 10:04 PM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
That's only on the gauge type bezel. The non gauge dash has the turn signals and 2 idiot lights in that center hole. I will be adding a tach to my non gauge dash soon and plan on installing 2 green lights in the panel for the turn signals. I have under dash gauges so I don't need the idiot lights anymore.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-08-2004, 10:06 PM   #10
lamar
lamar's Avatar
I saw one on ebay a few minutes ago with white gauge faces.
lamar is offline   Reply With Quote
Old 10-08-2004, 10:18 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Here's one with 130 mph speedo & 7K tach...notice how the speedo & fuel gauge are the same size. Sorry, I don't have any directions.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 10-09-2004, 04:47 AM   #12
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Hey pickmup, is the speedo accurate? what model/car did these gauges come out of?
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 05-29-2005, 10:53 PM   #13
jamal
jamal's Avatar
Will the tach work on a 6 cylinder as well?
jamal is offline   Reply With Quote
Old 05-29-2005, 11:28 PM   #14
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
Not without a recalabration.
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
