Old 12-17-2009, 02:03 AM   #1
Sicboy
Sicboy's Avatar
Indicator bulb wire color
What color is the wire to the left turn signal indicator bulb in the instrument panel? I've got two bulbs hanging under the dash and neither work, both with new bulbs.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 12-17-2009, 11:50 AM   #2
ChevySixty6
ChevySixty6's Avatar
Re: Indicator bulb wire color
You might do a search on this forum or jump over to the electrical one. I've seen the wiring diagram on here several times. I do know the dash lights are all grey wires.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 12-17-2009, 08:27 PM   #3
Sicboy
Sicboy's Avatar
Dude, I always search first. Couldn't find anything, that's why I asked. Anyone else know the color?
Old 12-17-2009, 09:44 PM   #4
bubba327
HOW long until spring??
bubba327's Avatar
If they are just hanging loose, try grounding them to frame.
Right Hand is dark blue-----left hand is light blue at dash lights
Found this in a 64 supplement to factory gm manual
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 12-17-2009, 10:07 PM   #5
Sicboy
Sicboy's Avatar
Thanks. Yea, I replaced both bulbs and tried grounding to the frame and plugging into dash socket, but nothing.
Old 12-17-2009, 10:18 PM   #6
LILRED66
LILRED66's Avatar
They will not come on unless the ignition switch is on and the turn signal lever is in the proper position. They should then blink, when the socket is grounded against the back of the gauge cluster. Also, check the flasher plugged into the fuse block, as well as the fuse.
LILRED66 is offline   Reply With Quote
Old 12-18-2009, 01:49 AM   #7
Sicboy
Sicboy's Avatar
Well duh...
Right indicator works, left does not, all turn signals work, flasher works, fuses good. Must be a wiring problem. I just needed to know which color wire was the left indicator. Thanks again Bubba.
Old 12-18-2009, 02:23 AM   #8
slepysal
slepysal's Avatar
maybe this will help you out
http://www.6066gmcguy.org/turnlights1.htm
but now you know the color
try using a test light to check the non working lead.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
