Old 12-17-2009, 11:16 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
71'-72' Master on 67'-68' booster ?
Will a 71'/72' disc brake master cylinder and proportioning valve mount and work properly in place of a 67' drum brake master and distribution block ? I have the disc master and the drum brake booster is on the truck . I am wanting to keep the factory booster .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-17-2009, 02:36 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 71'-72' Master on 67'-68' booster ?
Are you changing the front to Disk? If so, it should work just fine. Some one chime in if I am in left field...The only difference I know is that the brake lines run different on the frame rails between those years and may need massaging to get to the Dis Block.
If your not running disks dont change it.
Smitty
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 12-18-2009, 08:43 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Smitty
Smitty
I am putting a 67' cab on a 72' swb 5 lug disc brake chassis and want to run the 72' master cylinder and prop valve on the 67' brake booster .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-18-2009, 09:20 PM   #4
71meangreenc10
The catalog shows two different part numbers for the boosters, maybe because of size, but there is a difference for some reason, I am not an engineer so I would say after finding out about the different sizes of boosters to call MP Brakes or a company that specializes in brakes to see if its safe. Thats the key,make sure its safe.
The way I read your post was that you were changing the whole system not splitting it(my fault). Why not just put a complete 72 setup on the 67?
Smitty
71 C30 Wrecker
Old 12-19-2009, 12:56 AM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
If I was you I would forget that 67 booster and install a new or rebuilt 72 booster. Don't take a chance on safety with some old raggedy 67 booster. JMHO.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 12-19-2009, 04:07 AM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Well the master cylinder will be new , but either booster will be used . It is my understanding that even if the booster fails i will still have manual brakes .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-20-2009, 12:05 AM   #7
STP67-72
STP67-72's Avatar
Hey Hotrod 80
The master cylinder and p- valve will work fine on the booster. Two different companies made the boosters. Bendix and Moraine ?? I think. I have used them on both through the years.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 12-20-2009, 02:27 PM   #8
trenz68
Damage Inc
trenz68's Avatar
Same setup i did..cool
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
