Oh,you can't buy that new
![]() Join Date: Apr 2000
17x 8's fit our trucks.
I have a nice set of 17x8 Torq thrust knock-offs here i am thinking about for the 75. they have a 4.5" backset. with the 1" thick adapter i will need to make them work that makes it 5.5" backset. With the coil spring only lowering in the front I am sure they will not hit the A-arms and I also want to do only the Shackle drop in the back. I want facts/opinions or ideas. I want full sidewall tires not rubber bands so what do you recommend for tire sizes. Front & rear. thanx, crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
6.0 powered square
Re: 17x 8's fit our trucks.
with the the spacer the back spacing will be 3.5 and for tire a 275/50
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
I would be concerned with them hitting the fender when you go over bumps if you use the spacer.
yeller
You won't need a front spacer...4.5" BS is factory, and because they are 17" wheels...they won't hit/rub anyhow.
I would run the spacer in the rear however, as the rear track with is about 1.5" narrower per side...3" overall./ It'll push out the wheels and make things look sooo much better. EDIT: You said adaptor...is the bolt pattern NOT 5 on 5 for the wheels or something?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 12-17-2009 at 01:25 PM. |
I agree with Jeff. I don't think you would need spacer for the front. Just like he said to make the rear look better.
I think the route you are taking will look sweet on the truck. Something a little more modern, but not too much. Can't wait to see them on there. |
yeah, thanx for he math correction factor.duh. lol
the ADAPTER is for the bolt pattern difference not just a spacer. If i dont like the look i may just buy the right bolt pattern for the front in only 7's (if avail) to keep them in.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. Last edited by crossy; 12-17-2009 at 02:48 PM. |
found out they make 17x7 in 5on5 pattern but only make 16x8's in 5 on5. so if I buy TWO new ones ??? Ill decide when i compare tire sizes most likely. i know they make EVERY imaginable size in 16" for not much $. 17's get pricey quick. thanx , crossy
