![]() Join Date: Sep 2008
need manual steering box
hey does anyone have a nice no slop manual box out there. the slop in mine is too much and kinda dangerous. i need one quick as it will be a christmas gift for my brother
Re: need manual steering box
I have one,it was on my truck till I converted to power stg. $20 plus shipping and it will probably fit in a USPS flat rate box
I have one too. Here is a picture. $45 shipped.
i need one with no slop at all. i have two but they have some play i am looking for a perfect one. and if i am not mistaken 4wd boxes are different from 2wd, but corredt me if i am wrong
when I get home from work, I will check, but I'm almost positive I have no slop at all, otherwise, it wouldn't be on my truck. I'm pretty anal!
Josh |
do you need 2WD or 4WD?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
4wd. am i right? i think the 2wd and 4wd are different
I have a 4WD, Do you need the drag link on it? Mine was from a 68 so it was on a flat frame...
4WD goes front to back and 2WD goes side to side...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 12-17-2009 at 06:10 PM. |
i'll get a better pic...
thats it. does it have any slop in it cause i needone thats like perfect cause i really only want to do this once. and i dont need the drag like but the pitman arm would be nice so i dont have to transfer mine
i'm pretty sure it's tight, how's $20 + shipping?
not to kill a sale but have you thought about powersteering? what year is your truck? I want to make sure it will bolt up to your frame. Send a pic of yours and we can compare.
i have a 1970 jimmy 4wd 307 4spd. i want to go power steering. do u have a complete set up. cause i would be interested
#13 |
I don't, I found that it takes awhile to build the parts list unless you shell out $$$ for everything at once.
I'll snap a pic and post it tonight. Is your frame area behind the box flat or dimpled?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 12-18-2009 at 12:15 PM. |
#14 |
Don't know if it's relevant but here is my 2 cents on these boxes. Most boxes mount to the inside of the frame. It is only the couple of years in the '67 - '72 range of pickups that these mount to the ouside of the frame. The 2 wheel drive models retain the pitman arm in the conventional spline and nut manner. The 4 wheel drive models, pitman arm is split and mounts to the steering shaft by clamping to it, much like a rag joint, where the bolt goes through a dimple in the shaft. Also, the 4 wheel drive arm is quite massive and has a 'dog-leg' bend, I believe, at the tapered hole end. When I was looking for mine, I found this ifo very interesting. Buy the way, I have one of each available If I convert mine back to a manual box.
#15 |
1969 Short, Fleet, and Beat
#16 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
All pickups, Suburbans and Blazers, both 2wd and 4wd from 1960 thru 1987 have the steering boxes mounted on the outside of the frame. In 1988 GM switched them to the inside of the frame since the frames are wider.
The 2wd and 4wd power boxes are identicle in appearance but the sector shafts are different between the two as well as the pitman arms differ. The 2wd sector shaft has 4 keyed positions, whereas the 4wd has only one, plus the notch for the pitman arm clamping bolt. So even though a 4wd box will bolt up in place of a 2wd box, the pitman arms won't interchange Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-05-2010 at 12:21 AM. |
#17 |
Born Psycho
![]() Join Date: Feb 2001
i have a nice tight steering box off a 73 4x4 that had very low miles on it--it was my dads truck and i converted it to power steering many years ago. it will bolt up perfectly on your 70. $45.00 shipped.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
