12-17-2009, 04:35 PM | #1 |
Torque specs for a L33 5.3 vortec
Hi I'm looking for the bolt Torque specs for a L33 5.3 vortec? I was sure I saw it here some place?
also with this being all aluminium engine do I need to put anything on these bolts before I torque them in? What about detailing the engine should I paint it or just leave it how it? Tell me what you think! Thanks
Rolled the dice and lost!! Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
12-17-2009, 04:41 PM | #2 |
Re: Torque specs for a L33 5.3 vortec
I would say you need anti-seize on good clean bolts to get proper torque on them. Dont know about the torque specs.
Tim |
12-17-2009, 04:45 PM | #3 |
This is for the LS1. Should be very similar.
EDIT: Trying to attach it Last edited by Lobie; 12-17-2009 at 04:46 PM. |
12-17-2009, 04:53 PM | #4 |
here
12-17-2009, 06:12 PM | #5 |
Do you have a link to this page as I can't read it must be getting old? or I need some glasses.
Rolled the dice and lost!! Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-17-2009 at 06:13 PM. |
12-17-2009, 06:51 PM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
LM4
The LM4 was an aluminum block version of the LM7, and had a short production life. It should not be confused with the L33. LM4 applications: * 2003-04 Chevrolet TrailBlazer EXT * 2004 GMC Envoy XL * 2004 Chevrolet SSR L33 Vin code "B" The L33 was an aluminum block version of the LM7, and was referred to as the Vortec 5300 HO in marketing materials. Power increased by 15 hp (11 kW), to 310 hp (230 kW), over the LM7, and torque was unchanged. It was only available on extended cab 4WD pickup trucks. Only 25% of trucks made in 2005 had the L33 engine. 325ftLbs torque per.... http://en.wikipedia.org/wiki/GM_Vortec_engine Clyde65
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 12-17-2009 at 06:52 PM. |
12-17-2009, 06:58 PM | #7 |
Thanks but I'm looking for the Torque Specs for the bolts on this L33
12-17-2009, 07:26 PM | #8 |
if rebuilding.... i understand its very important to blow out bolt holes with compressed air.... easy to damage block if fluids are trapped in bottom of bolt hole.
12-18-2009, 09:43 AM | #9 |
ttt
Thanks!
12-18-2009, 09:52 AM | #10 |
Most of the LS1 bolts are torq to yield unless you replace them with ARPs.
Where you purchasing the bolts? The can provide you with the information you need.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
12-18-2009, 08:36 PM | #11 |
Pm me your email and I will send them to you. They are a PDF file that was to big to attach to this forum.
12-18-2009, 08:44 PM | #12 |
This is for an LS2 but should apply?
Fastener Tightening Specifications Application Specification Metric English Camshaft Position (CMP) Sensor Bolt 12 N·m 106 lb in CMP Sensor Wire Harness Bolt 12 N·m 106 lb in Camshaft Retainer Bolts - Hex Head Bolts 25 N·m 18 lb ft Camshaft Retainer Bolts - TORX® Head Bolts 15 N·m 11 lb ft Camshaft Sprocket Bolts 25 N·m 18 lb ft Clutch Pressure Plate Bolts 70 N·m 52 lb ft Connecting Rod Bolts - First Pass 20 N·m 15 lb ft Connecting Rod Bolts - Final Pass 85 degrees Coolant Air Bleed Pipe and Cover Bolts 12 N·m 106 lb in Coolant Temperature Sensor 20 N·m 15 lb ft Crankshaft Balancer Bolt - Installation Pass to Ensure the Balancer is Completely Installed 330 N·m 240 lb ft Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes 50 N·m 37 lb ft Crankshaft Balancer Bolt - Final Pass 140 degrees Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence 20 N·m 15 lb ft Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence 80 degrees Crankshaft Bearing Cap M10 Studs - First Pass in Sequence 20 N·m 15 lb ft Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence 51 degrees Crankshaft Bearing Cap M8 Bolts 25 N·m 18 lb ft Crankshaft Oil Deflector Nuts 25 N·m 18 lb ft Crankshaft Position (CKP) Sensor Bolt 25 N·m 18 lb ft Crankshaft Rear Oil Seal Housing Bolts 30 N·m 22 lb ft Cylinder Head M11 Bolts - First Pass in Sequence 30 N·m 22 lb ft Cylinder Head M11 Bolts - Second Pass in Sequence 90 degrees Cylinder Head M11 Bolts - Final Pass in Sequence 70 degrees Cylinder Head M8 Bolts - in Sequence 30 N·m 22 lb ft Cylinder Head Coolant Plug 20 N·m 15 lb ft Engine Block Coolant Drain Hole Plug 60 N·m 44 lb ft Engine Block Coolant Heater 40 N·m 30 lb ft Engine Block Oil Gallery Plug 60 N·m 44 lb ft Evaporative Emission (EVAP) Canister Purge Solenoid Valve Bolt 50 N·m 37 lb ft Exhaust Manifold Bolts - First Pass 15 N·m 11 lb ft Exhaust Manifold Bolts - Final Pass 20 N·m 15 lb ft Exhaust Manifold Heat Shield Bolts 9 N·m 80 lb in Exhaust Manifold Studs 20 N·m 15 lb ft Flywheel Bolts - First Pass 20 N·m 15 lb ft Flywheel Bolts - Second Pass 50 N·m 37 lb ft Flywheel Bolts - Final Pass 100 N·m 74 lb ft Front Cover Bolts 25 N·m 18 lb ft Fuel Injection Fuel Rail Bolts 10 N·m 89 lb in Ignition Coil Bracket-to-Valve Rocker Arm Cover Stud 12 N·m 106 lb in Ignition Coil-to-Bracket Bolts 10 N·m 89 lb in Intake Manifold Bolts - First Pass in Sequence 5 N·m 44 lb in Intake Manifold Bolts - Final Pass in Sequence 10 N·m 89 lb in J 41798 M8 Bolt 25 N·m 18 lb ft J 41798 M10 Bolts 50 N·m 37 lb ft Knock Sensor Bolts 20 N·m 15 lb ft Motor Mount Bracket Bolts 50 N·m 37 lb ft Oil Cooler Bolts 12 N·m 106 lb in Oil Filter 30 N·m 22 lb ft Oil Filter Fitting 55 N·m 40 lb ft Oil Level Indicator Tube Bolt 25 N·m 18 lb ft Oil Level Sensor 20 N·m 15 lb ft Oil Pan Closeout Cover Bolt - Left Side 9 N·m 80 lb in Oil Pan Closeout Cover Bolt - Right Side 9 N·m 80 lb in Oil Pan Cover Bolts 12 N·m 106 lb in Oil Pan Drain Plug 25 N·m 18 lb ft Oil Pan M6 Bolts - Oil Pan-to-Rear Oil Seal Housing 12 N·m 106 lb in Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover 25 N·m 18 lb ft Oil Pressure Sensor 35 N·m 26 lb ft Oil Pump Cover Bolts 12 N·m 106 lb in Oil Pump Relief Valve Plug 12 N·m 106 lb in Oil Pump Screen Nuts 25 N·m 18 lb ft Oil Pump Screen-to-Oil Pump Bolt 12 N·m 106 lb in Oil Pump-to-Engine Block Bolts 25 N·m 18 lb ft Spark Plugs 15 N·m 11 lb ft Throttle Body Bolts 10 N·m 89 lb in Timing Chain Dampener Bolts 25 N·m 18 lb ft Valley Cover Bolts 25 N·m 18 lb ft Valve Lifter Guide Bolts 10 N·m 89 lb in Valve Rocker Arm Bolts 30 N·m 22 lb ft Valve Rocker Arm Cover Bolts 12 N·m 106 lb in Water Inlet Housing Bolts 15 N·m 11 lb ft Water Pump Bolts - First Pass 15 N·m 11 lb ft Water Pump Bolts - Final Pass 30 N·m 22 lb ft © 2009 General Motors. All rights reserved. |
12-18-2009, 08:53 PM | #13 |
or a bigger list
Engine Torque Specs Application Spec Accelerator Control Cable Bracket Bolts 89 lb in Air Conditioning Compressor Bolts 37 lb ft Air Conditioning Compressor Bracket Bolts 37 lb ft Air Conditioning Idler Pulley Bolt 37 lb ft Air Conditioning Tensioner Bolt 18 lb ft Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts 15 lb ft Camshaft Retainer Bolts 18 lb ft Camshaft Sensor Bolt 18 lb ft Camshaft Sprocket Bolts 26 lb ft Catalytic Converter Nut 18 lb ft Connecting Rod Bolts - First Design (First Pass) 15 lb ft Connecting Rod Bolts - First Design (Final Pass) 60 degrees Connecting Rod Bolts - Second Design (First Pass) 15 lb ft Connecting Rod Bolts - Second Design (Final Pass) 75 degrees Coolant Temperature Gauge Sensor 15 lb ft Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft Crankshaft Balancer Bolt (Final Pass) 140 degrees Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees Crankshaft Bearing Cap Side Bolts 18 lb ft Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees Crankshaft Oil Deflector Nuts 18 lb ft Crankshaft Position Sensor Bolt 18 lb ft Cylinder Head Bolts (First Pass all M11 Bolts in Sequence) 22 lb ft Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence) 90 degrees Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head) 90 degrees Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence) 50 degrees Cylinder Head Bolts (M8 Inner Bolts in Sequence) 22 lb ft Cylinder Head Coolant Plug 15 lb ft Cylinder Head Core Hole Plug 15 lb ft Drive Belt Idler Pulley Bolt 37 lb ft Drive Belt Tensioner Bolts 37 lb ft Engine Block Coolant Drain Plugs 44 lb ft Engine Block Heater 30 lb ft Engine Block Oil Gallery Plugs 44 lb ft Engine Coolant Air Bleed Pipe Bolts and Studs 106 lb in Engine Crossmember Bolts (Large) 107 lb ft Engine Crossmember Bolts (Small) 92 lb ft Engine Flywheel Bolts (First Pass) 15 lb ft Engine Flywheel Bolts (Second Pass) 37 lb ft Engine Flywheel Bolts (Final Pass) 74 lb ft Engine Flywheel-to-Torque Converter Bolts 44 lb ft Engine Front Cover Bolts 18 lb ft Engine Mount Heat Shield Nuts 89 lb in Engine Mount Stud-to-Engine Block 37 lb ft Engine Mount Through Bolts 70 lb ft Engine Mount Through Bolt Nuts 59 lb ft Engine Mount-to-Engine Block Bolts 37 lb ft Engine Rear Cover Bolts 18 lb ft Engine Service Lift Bracket M10 Bolts 37 lb ft Engine Service Lift Bracket M8 Bolt 18 lb ft Engine Valley Cover Bolts 18 lb ft Engine Wire Harness Clip Bolt 37 lb ft Engine Wire Harness Ground Strap Bolt 37 lb ft Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass) 89 lb in EGR Valve Bolts (Final Pass) 22 lb ft EGR Valve Pipe-to-Cylinder Head Bolts 37 lb ft EGR Valve Pipe-to-Exhaust Manifold Bolts 22 lb ft EGR Valve Pipe-to-Intake Manifold Bolt 89 lb in Exhaust Manifold Bolts (First Pass) 11 lb ft Exhaust Manifold Bolts (Final Pass) 18 lb ft Exhaust Manifold Heat Shield Bolts 80 lb in Exhaust Manifold Pipe Nuts 26 lb ft Front Shock-to-Engine Crossmember Bolts 48 lb ft Fuel Injection Fuel Rail Bolts 89 lb in Generator Bracket Bolts 37 lb ft Generator Rear Bracket-to-Engine Block Bolt 18 lb ft Generator Rear Bracket-to-Generator Bolt 18 lb ft Ground Strap Bolt (at Rear of Cylinder Head) 37 lb ft Ignition Coil-to-Bracket Bolts 106 lb in Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts 106 lb in Intake Manifold Bolts (First Pass in Sequence) 44 lb in Intake Manifold Bolts (Final Pass in Sequence) 89 lb in Knock Sensors 15 lb ft Oil Filter 22 lb ft Oil Filter Fitting 40 lb ft Oil Level Indicator Tube Bolt 18 lb ft Oil Level Sensor 115 lb in Oil Pan Baffle Bolts 106 lb in Oil Pan Closeout Cover Bolt (Left Side) 106 lb in Oil Pan Closeout Cover Bolt (Right Side) 106 lb in Oil Pan Cover Bolts 106 lb in Oil Pan Drain Plug 18 lb ft Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover) 18 lb ft Oil Pan M6 Bolts (Oil Pan-to-Rear Cover) 106 lb in Oil Pressure Sensor 15 lb ft Oil Pump-to-Engine Block Bolts 18 lb ft Oil Pump Cover Bolts 106 lb in Oil Pump Relief Valve Plug 106 lb in Oil Pump Screen Nuts 18 lb ft Oil Pump Screen-to-Oil Pump Bolt 106 lb in Oxygen Sensor 31 lb ft Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud) 106 lb in Power Steering Pump Bolts 18 lb ft Power Steering Pump Bracket Bolts 18 lb ft Spark Plugs (Cylinder Heads-New) 15 lb ft Spark Plugs (all Subsequent Installations) 11 lb ft Throttle Body Bolts 106 lb in Transmission Housing Bolt 37 lb ft Valve Lifter Guide Bolts 106 lb in Valve Rocker Arm Bolts 22 lb ft Valve Rocker Arm Cover Bolts 106 lb in Water Inlet Housing Bolts 11 lb ft Water Pump Bolts (First Pass) 11 lb ft Water Pump Bolts (Final Pass) 22 lb ft Water Pump Cover Bolts 11 lb ft T-56 Transmission Torque Specs Application Spec Backup Lamp Switch 20 lb ft Clutch Actuator Cylinder Bolt 71 lb in Clutch Housing Bolt 37 lb ft Control Lever Handle Bolt 18 lb ft Gear Select/Skip Shift Solenoid 30 lb ft Reverse Lockout Assembly Bolt 13 lb ft Reverse Lockout Solenoid 30 lb ft Shift Control Bolt 13 lb ft Shift Control Closeout Boot Bolt 18 lb in Shift Control Knob 27 lb ft Transmission Bolt 37 lb ft Transmission Drain/Fill Plug 20 lb ft Transmission Mount Bolt 38 lb ft Transmission Mount Nut 77 lb ft Transmission Support Bolt 66 lb ft Vehicle Speed Sensor Bolt 89 lb in Last edited by Thealien; 01-26-2010 at 03:41 PM. |
