Old 12-17-2009, 06:54 PM   #1
jame
E-Brake Cable help
The bracket that holds the cable to the trailing arm on each side is too far gone for reuse on my 63. I called inline tube. lmc, ect all the regulars they either do not have it or know what it is. I thought they would come on the new cables but guess not - any one know a supplier or local part store part # for these. I know they have to be out there some were. I checked two other trucks and they were a ball of rust also. Thanks
1963 chevy shortstep 327
1965 c60 292
2007 Ram 3500 5.9 cummins
jame is offline   Reply With Quote
Old 12-17-2009, 07:01 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: E-Brake Cable help
if you are referring to the bracket that is attached to the trailing arm, i have not seen those reproduced, but they could exist. could you weld a washer to the bracket and notch it, slide the cable in, and clamp it with the mickey mouse looking clip?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-17-2009, 07:40 PM   #3
jame
well thats not good to hear -- there is not enough of these to try and rework.
1965 c60 292
Old 12-17-2009, 09:20 PM   #4
Big Fenders
You posted that you are missing the brackets that attach to the trailing arms that hold the EB cable.. I have a 63 short step side and the new cables that I have are too long..maybe I'm missing what your talking about. Anyone with a pic would be a big help.
The cables that I ordered are from truckandcarshop.com but most of the parts suppliers have them.
Bob
Big Fenders is offline   Reply With Quote
Old 12-17-2009, 09:31 PM   #5
TR65
TR65's Avatar
Jame,
Here is how mine are but I changed the cable to a different kind. Here also is some details of the originals. They would be easy to fab up from some flat stock. Or you could start with an electrical cable clamp, or an Adel clamp and work up a good solution. Hope this helps some and good luck.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 12-17-2009, 09:32 PM   #6
jame
The brackets slide on to the forward end of the rear cables and then bolt to the trailing arm outer side. They keep the cable from slipping forward when the hand brake is applied. Mine were still on the old cables just too rusty to reuse. If your cables are too long I would guess they are for a LWB rather than SWB.
1965 c60 292
Old 12-17-2009, 09:36 PM   #7
jame
Thanks for the pics -- Your set up looks very nice. I guess I'll make a bracket I just thought if they were still made I would take the lazy way out.
1965 c60 292
Old 12-17-2009, 09:41 PM   #8
Big Fenders
I did consider that [LWB].
TR65 thanks for the pics...
Bob
Old 12-18-2009, 12:38 AM   #9
62gmc910
62gmc910's Avatar
would LWB make any difference ? the trailing arms are the same
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-18-2009, 09:31 PM   #10
Big Fenders
The parts book that I have show a different part number for SWB and for LWB so there is a difference.
Bob
