Old 12-17-2009, 06:59 PM   #1
jdaley
Parking Brakes jambs throttle
I have just picked up a C20 1977.
The parking brake cannot be used because it holds the trottle pedal down. Everything looks straight, so does anybody know what the solution is, I thought shift the throttle mechanism sideways about 3 inches.
jdaley is offline   Reply With Quote
Old 12-17-2009, 09:50 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Parking Brakes jambs throttle
Welcome to the forum jdaley. I am rather confused on your issue. I'm not sure how the parking brake could cause a problem with the throttle.
Can you post pics so we might be able to help?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-17-2009, 10:27 PM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
right hand drive I assume
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-17-2009, 11:33 PM   #4
jdaley
RHD yes
If I push the brake pedal down it locks against the middle of the throttle pedal. Nothing looks bent or out of place, its bewilderin.
I thought of shifting the accelerator pedal 3inches closer to the main brake pedal.
But it seems strange!
Old 12-17-2009, 11:48 PM   #5
wfomkivdrvr
HORSEPOWER JUNKIE
wfomkivdrvr's Avatar
why dont you adjust the rear brakes and then the park brake so that it doesn't travel so far down!
67 C20 fleetside custom camper
69 El Camino
72 Camaro
52 Dodge b3b 108 pickup
wfomkivdrvr is offline   Reply With Quote
Old 12-17-2009, 11:49 PM   #6
wfomkivdrvr
HORSEPOWER JUNKIE
Oh yeah welcome
69 El Camino
72 Camaro
Old 12-18-2009, 12:44 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah, I saw his location after I posted. RHD crossed my mind, but I'm still perplexed as to why it's happening.
Articles-
"Refining Sierra"
Old 12-18-2009, 01:12 AM   #8
flamingbig10
6.0 powered square
it took me a hour to figure it out
Aaron
Old 12-18-2009, 01:19 AM   #9
Stitch
Location: Where I come from, it's cornbread and chicken...
I think that the whole assembly may be mounted wrong...that's my only guess without pictures...you're going to have to get up under there and see exactly what's going on up there...for some reason maybe you have a LHD accelerator pedal assembly and when it's mounted in a RHD configuration it puts it over too far...or you can just do as already stated and adjusted the parking brake so it doesn't go down as far and doesn't touch the gas pedal...
Stitch is offline   Reply With Quote
Old 12-18-2009, 02:16 AM   #10
jdaley
Thanks for the welcome.
I will try the adjustment technique first.
John Daley
Melbourne, Australia
1946 Chev Ute
1977 Chev Tray
Road racing sidecars
Old 05-03-2011, 06:46 AM   #11
jdaley
I finally fixed this problem.
I moved the throttle bracket left about 1 inch with new bolts and bent the throttle bar sideways the same amount and everything now works.
Its nice having a secondary brake taht works.
John Daley
1946 Chev Ute
1977 Chev Tray
Old 05-03-2011, 08:55 AM   #12
bb1979
bb1979's Avatar
Yep it's a common problem with all pickups over here solution is exactly what you have done.
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 05-03-2011, 09:02 AM   #13
HzSandman
I had the exact same issue on my 1990 RHD C1500. It almost cost me a new pickup actually. A mate was reversing down the boat ramp so I could load my boat on the trailer. Not knowing that the park brake used to go right down to the throttle pedal he pushed it on whilst still in reverse. Jamming the throttle to the floor.....The water only came up to the back of the doors, luckily he quickly threw it into Neutral. One very very hairy moment.
Glad you got it sorted, its a less than average setup and I'm really suprised that they pass engineering like this.
Just picked up a C20 myself, what are your plans ?
HzSandman is offline   Reply With Quote
Old 05-03-2011, 06:18 PM   #14
jdaley
I intend to keep the 292, fit lpg, cut and polish the cab and leave it. I will fit air, silencing of cabin.
I extended the exhaust pipe 3M to get a quiter ride.
I race sidecars and the machine and all bits fits nicely on the deck.
I love the wide bench seat, I can get 4 across
You know, when I first asked about this matter, it seemed like I was the only person who had the problem.
John Daley
1946 Chev Ute
1977 Chev Tray
Old 05-04-2011, 06:36 AM   #15
bb1979
bb1979's Avatar
If you have the seat re trimmed, add something like an extra 2" of padding on each side and you can legally change the seating capacity to 4 people after fitting a fourth belt, works well as long as you don't have four big blokes in there, works real well when out cruising with a mate and you pick up a couple of chicks
Old 05-04-2011, 08:53 AM   #16
jdaley
good tip, thanks
John Daley
1946 Chev Ute
1977 Chev Tray
