Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-17-2009, 07:20 PM   #1
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Need a better PCV breather, I think.
I'm still working the kinks out of the engine in the sig. Today I finally realized what's been causing my oil leaks. With two 3/4" bottom vented Specter/Mr Gasket breathers installed one in each valve cover, oil starts to bubble out between the head and intake manifold once the RPM's get above idle. When I pull the breathers out, the oil stops leaking.
I'm guessing this means I need something a little more performance oriented. What kind of breather should I install that will work correctly?
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
