Old 12-17-2009, 08:29 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
to stroke or not to stroke....that is the question?
Well I am at a crossroads. I was going to go with a 454 but have decided to sell the truck at a later time and would like to keep the 454 for myself. here lies the questions. I have two options, one is an old 350 that I take and get machined and make it a 383 buy the rotating assemble and go on my way or I have a newer 5.3 with less that 30km on it. Which engine should I use? I would like to consider the option that would make the truck more valuable, what do you all recommend? Info on the truck, it is a 70 lwb 4x4 and will be using a 700r4/ np241. I would like to run 35''x16'' tires as well.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 12-17-2009, 10:01 PM   #2
Wildstreak
Wildstreak's Avatar
Re: to stroke or not to stroke....that is the question?
any one? taking all opinions.
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 10:35 PM   #3
72chevyk10
I built it
72chevyk10's Avatar
id stroke the 454!! im thinkin of building a 489 for my truck
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 12-17-2009, 10:38 PM   #4
72chevyk10
I built it
72chevyk10's Avatar
wait never mind. i didnt see that you wanted to sell the truck its goin in in that case id do the 383. i just like the old school engines better
Old 12-17-2009, 10:49 PM   #5
OhOneWS6
OhOneWS6's Avatar
No matter what you do, buyers will want something different. Unless you are putting it back original nothing is going to make it "More Valuable". Everything is a personal preference.
OhOneWS6 is offline   Reply With Quote
Old 12-17-2009, 10:49 PM   #6
Wildstreak
Wildstreak's Avatar
shhhhhhh Im going to lol, but I want to buy a blazer first or swb to stick it in.
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 10:51 PM   #7
Wildstreak
Wildstreak's Avatar
Originally Posted by OhOneWS6 View Post
No matter what you do, buyers will want something different. Unless you are putting it back original everything is a personal preference.
thats what I figure and it will be way easier to do the 383 than the 5.3 so I think Im just going to build the 383. Now I just have to figure out all the details on which parts to order to stroke my 350.
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 10:57 PM   #8
haysonj
haysonj's Avatar
I went with a FI 383 T400 with a gear vendors. 410 gears 35x12.50x16.5 tires cruises 65 at around 2000 RPM and still has enough power too light those big tires in low gear. But then if you built it you wouldn't want to sell it.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-17-2009, 11:01 PM   #9
Wildstreak
Wildstreak's Avatar
I hear ya there, thats why I decided not to use the 454 lol
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 11:04 PM   #10
tonypaul
tonypaul's Avatar
Im currently gathering parts to put a brand new 8.1L crate engine in my 68 GMC swb. I will tell you unless you get everything, and Im mean everything, it will nickel and dime you to death. Even though I got a smokin deal on the engine, the harness, the electronic transmission, the headers, mass air, electronic pedal, the list goes on and on..... it gets expensive. If I just wasnt set on doing my first non carb engine, I would just do a rebuild with some really good parts... In My opinon you just cant go wrong with a stroker engine, and it really isnt that much moore for what you get if your putting it in something that already had a carb engine in it.
tonypaul is offline   Reply With Quote
Old 12-17-2009, 11:16 PM   #11
Wildstreak
Wildstreak's Avatar
and that right there is another reason I would like to hold off on a newer engine.....theres nicer ones out there lol. My dad has an 08 chevy hd2500 gas and its a beast, I would love to get one of those motors instead of the 5.3. But just like you say it will nickle and dime you till your head hurts.
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 11:25 PM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
There are plenty of options for 383's for sure. I know I loved both the ones I had.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-17-2009, 11:34 PM   #13
Wildstreak
Wildstreak's Avatar
yea Im set on 383 now I just need to figure out what kit to order ala flat +7cc or dome +18cc pistons any ideas? lol not sure what my head size is but I would like to run 9-10 compression ratio
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 11:43 PM   #14
vectorit
What?
vectorit's Avatar
If it were me.
I'd get rid of the 454 rotating assembly, punch out that 454 block and put in a forged steel 396 crank/rods. Big bores, snapy low end torque, matched with low gears.
Heads, I'd go with a oval port semi open chamber if you are on a budget. If you have a few bucks, then I'd look at the new stuff out there in the catalogs and get exactly what you want.
Induction, sky is the limit. But if on a budget, stay with a good dual plane.
Just my .02
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-17-2009, 11:50 PM   #15
Wildstreak
Wildstreak's Avatar
oh something like that will be happening rather shortly to the bbc, but i would like to save it for the blazer I want really bad right now lol
57 chevy 4x4
68 burb 2wd:
Old 12-17-2009, 11:55 PM   #16
Dieselwrencher
You better figure out what you have for heads before ordering anything so you're not doing that twice.
Ryan
Old 12-17-2009, 11:59 PM   #17
Wildstreak
Wildstreak's Avatar
I was looking at a site and the kit I was looking at works with any size head cc, its just seems the differences in head size would cause differences in the compression, or am I wrong?
57 chevy 4x4
68 burb 2wd:
Old 12-18-2009, 07:29 AM   #18
jim zag
ENGINE BUILDER
jim zag's Avatar
You need to pick the cam you want and then decide on the compression ratio. Small cam closer to 9 big cam closer to 10.
JIM ZAG
jim zag is offline   Reply With Quote
Old 12-18-2009, 01:08 PM   #19
Wildstreak
Wildstreak's Avatar
I was thinking a 220 or 230 cam, I have a comp cam right now but lost the sheet for it, if i can find that, I may already have the cam I want.
57 chevy 4x4
68 burb 2wd:
Old 12-18-2009, 04:33 PM   #20
Dieselwrencher
You are right. That will be the final element besides the piston for compression.
Ryan
Old 12-18-2009, 08:44 PM   #21
Wildstreak
Wildstreak's Avatar
sweet, Im new to this whole engine building process but I am learning tons! thanks for all your help so far guys
57 chevy 4x4
68 burb 2wd:
