Under Construction
Steering Wheel Removal
Don't know what I'm doing wrong but my steering wheel doesn't want to come off.Is there a trick to getting it off or are they just hard to remove?I tried the search but couldn't find anything.Thanks in advance.
72 chevy 4x4-my project 67-72chevytrucks.com/vboard/showthread.php?t=368210 94 Nissan 4x4-Daily Driver and off road beater 03 Saab 9-3 -tripper 90 Polaris Trail Boss- 2 Stroker |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Re: Steering Wheel Removal
rent a steering wheel puller from your auto parts store
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
Registered Chevy Owner
I went to auto zone. I dont know if they are nation wide, but $20 down and $20 back, and it worked like a charm.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
Under Construction
So it just needs a little encouragement,huh?! Thanks,I'll have to check into that.
That's correct. The nut has pressed the wheel onto the steering shaft. A steering wheel puller works great. You can either rent one or buy one. No problem. Take it easy.
Moderator
![]() Join Date: May 2007
You can buy this kit at Harbor Freight for $10. It will remove steering wheels, pullies, etc. Great investment.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
69 Fleetside
![]() Join Date: Mar 2009
Just buy a steering wheel puller - they are $15 at Schucks...
Under Construction
Thanks for your help,everyone.Before I go buy one,I'm going to check with my local mechanic.He may have one I can borrow.
times are tough, and some of us may not have 20 bucks...
now i know this may sound shady but its worked many times for me. pappy rust taught me this one. take the nut off and find a regular nut that threads onto the shaft. thread it on just enought that the shaft dosent protrude out of the nut. lace your arm thru the wheel pull it toward you. and with the other bump the nut with a small hammer. be sure you arent hitting the shaft just the nut. and be gentle you can still damage the threads. it should pop off without too much force. and dont hit yourself in the nose with the wheel when it pops off. and a little anti-seize on it before it goes back on. |
... sounds like a good way to lose some teeth.
do yourself a favor and find a puller ... rent, buy or borrow, it's still cheaper than the dental bills. |
20' Daredevil (Ret)
![]() Join Date: May 2003
I have one like this that I bought many years ago. It was cheap and works great.
![]() Join Date: May 2005
Yeah they're not too expensive, and it's surprising how many times I've actually used it.
#13 |
Under Construction
I'll probably end up getting a puller somewhere.We tried putting pressure on it and tapping the nut -kind of the same method I used to slide the back axle out of my four wheeler-but it wouldn't budge.I didn't know if there were any tricks or something I missed,but it sounds like I just need a puller.Hopefully I'll get to it today.
72 chevy 4x4-my project 67-72chevytrucks.com/vboard/showthread.php?t=368210 94 Nissan 4x4-Daily Driver and off road beater 03 Saab 9-3 -tripper 90 Polaris Trail Boss- 2 Stroker Last edited by justagoodolboy; 12-18-2009 at 12:24 PM. |
#14 |
Use the puller. Guys used to do the hammer trick all the time but it is too easy to damage the collapsible columns and shafts and or the steering boxes on older trucks with solid shafts. Some of those things we "used to do all the time" are made obsolete by the designs of the newer and I mean newer by 68 and up rigs.
From experience it isn't fun to have to repair a steering shaft that someone collapsed by wacking it with a hammer to get the wheel off. One of them is in my 71 and was damaged when one of my uncles redneck buddies changed a turn signal switch for him. When I pulled the stock wheel off to put my custom wheel on the shaft slid down inside the column. As several said, if you are low on bucks and can't borrow one. Go to Autozone and hand them some money on their rental program, use it and take it back and get the money back. Last edited by mr48chev; 12-18-2009 at 12:36 PM. |
#15 |
Under Construction
My mechanic/friend said he has one I can borrow so I'm picking it up in a few minutes and then I'm off to my buddy's shop to keep yanking my interior.
#16 |
Under Construction
Worked like a charm! Thanks, guys.
#17 |
Great! Glad it worked for ya!
#18 |
![]() Join Date: Nov 2022
I've got a 1967-68 steering wheel and I don't see how the pullers I am finding work. Napa and O'Reilly's have them to borrow for free but j shaped hooks are too fat to fit between the column and wheel and the horn bowl prevents and puller bolt for screwing in. Do you need a special puller for a 1967 wheel?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
#19 | |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#20 |
![]() Join Date: Jan 2001
To expand on that, you remove the horn button and the three screws that hold the horn ring. Under that you'll find two bolt holes, one on each side of the steering wheel nut. Remove the nut, thread a bolt through the puller on each side of the steering wheel hub, and tighten the puller until the wheel comes off.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#21 |
Thanks. I'm not sure why that didn't occur to me when I looked at it, that I could take the bowl off. Thanks.
#22 | |
It's fine thread on GM so not always easy to find a nut that fits. I'm with the get a puller camp. They are handy for balancers too.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#23 | |
Do Not Use This Method you stand the chance of pulling the steering shaft upwards and from the lower steering column bearing. I know , this has happened to me . As the old saying goes , use the wright tool for the job. Vic |
#24 | |
![]() Join Date: Jun 2022
I originally borrowed another type (a thing actually called "steering wheel puller), and it was a no-go for me
1970 C10 Custom longbed 350/350 |
