Old 12-17-2009, 11:07 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
8'fleetside bed dissasembly
hey guys im trying to take the dents out of my bed particularly the bed sides and front header panel, i have an 8 ft. fleetside bed off of a 70. does this bed just unbolt or are the bed sides welded to the inner walls of the box? it would be alot easier to unbolt the bedside like it was a fender and then do the bodywork.
gmc1971harwich is offline   Reply With Quote
Old 12-17-2009, 11:30 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 8'fleetside bed dissasembly
There are a couple of welds on each side near the floor by the tailgate you will have to cut.. but all the rest unbolts...
A little hint on all the bolts on the floor.. DO NOT unbolt them.. use a 1/2" drive 6 point socket and ratchet, tighten up the nuts till they snap off.. It will save you hours of grief.. (some will still spin and you will have to cut them off)
Its less time consuming to break em off and buy new ones over trying to loosen and remove.. they will all just end up spinning in the holes.. and frustrate you to no end... It will end up taking up most of a day dissasembling it..
Livrat is offline   Reply With Quote
Old 12-18-2009, 12:51 AM   #3
gcsupraman
gcsupraman's Avatar
I just did this on my truck three weeks ago. I used a wrench or air ratchet on the first side and they will all just spun which forced me to grind all the heads off and punch them out. On the other side I used an impact gun and had a friend push down on the bolt with his hand in a glove and not a single one spun.
As stated above, just a small weld that can easily be grinded.
-Greg
gcsupraman is offline   Reply With Quote
Old 12-18-2009, 12:31 PM   #4
red69ss
Burnouts are therapeutic
red69ss's Avatar
I drilled the heads out and off the carriage bolts from the top and punched them out ,this made it much easier than trying to grind them from the bottum and caused no damage.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 12-18-2009, 05:04 PM   #5
gmc1971harwich
i cant seem to find a thread on here about the bed disassembly process with photos, does anybody know if theres a thread on here for that?
Old 07-18-2015, 12:55 PM   #6
bopper_702
bopper_702's Avatar
i love the darn search bar... i been going at it with my bed for 3 days straight and not one bolt off yet. super old post but thank you my friends. lol
time to fffff some bolts up lol
1997 GMC SIERRA STEPSIDE
1986 CHEVY C10
1968 CHEVY C20
-JOSH
IG:bopper702
bopper_702 is offline   Reply With Quote
Old 07-18-2015, 12:57 PM   #7
bopper_702
bopper_702's Avatar
-Greg
ima try this as well if the first one dont come out. im breaking em
1986 CHEVY C10
1968 CHEVY C20
-JOSH
IG:bopper702
Old 07-18-2015, 10:24 PM   #8
mike16
Yes! Exactly! dont wrench or grind them all day long. drill them out. much easier and mor forgiving of the parts you want to save.
By the way... a quart of linseed oil covers the area of a wooden bed exacly and every six month.
Thats why British ships lasted , in some cases for over a hundred years in service.
also..... if your wood is soaked in linseed oil the splinters will not cause infection.
mike16 is offline   Reply With Quote
