12-17-2009, 11:59 PM | #1 |
4x4 axle
My son's 1972 chevy has the 3/4 ton running gear with the 8 lug whels. It has a GM 12 bolt axle in the front. I also have an extra 12 bolt front axle with 6 lug rotors. If I swap the axles, can I just install the 8 lug rotors on the new axle or will I need to change the steering knuckles?
Thanks, Colby. |
12-18-2009, 12:43 AM | #2 |
Member #1049
Re: 4x4 axle
The knuckles are the same between 1/2 ton (6 lug) and 3/4 ton (8 lug) all you would need to change are the spindles.. backing plate/caliper mounts and the rotors..
12-18-2009, 12:45 AM | #3 |
I'm a poor spectator
Re: 4x4 axle
X2 and it should be a Dana 44.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
12-18-2009, 02:37 AM | #4 |
Re: 4x4 axle
Thank you both! I am actively looking for a decent affordable Dana 44, but since winter's here and his front axle is broken we will have to make do.
12-18-2009, 02:39 AM | #5 |
Re: 4x4 axle
what did he break?
12-18-2009, 07:10 AM | #6 |
Re: 4x4 axle
Yeah,what`s wrong with the axle in it now?Maybe we can suggest another solution.
12-18-2009, 08:25 AM | #7 |
Re: 4x4 axle
Also make sure if swapping that you don't mix gear ratios. The front and rear have to match.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-18-2009, 10:30 AM | #8 |
Re: 4x4 axle
Yup, no such thing as a GM 12bolt front axle and maost everything on a D44 is interchangable. Post up some pics and we can confirm what you have.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
12-18-2009, 08:25 PM | #9 |
Re: 4x4 axle
What part of oregon are you in? I have a D44, closed knuckle, drum (4:10 I think) that im planing of swaping out of mine. Its not the best but you could use it for parts or a replacement in a pinch.
12-19-2009, 10:43 AM | #10 |
Happy to be here
Re: 4x4 axle
Can we assume you are offering to give him the left over parts? That sounds like a very generous offer.
12-20-2009, 03:51 AM | #11 |
Re: 4x4 axle
not to kick a gift horse in the nuts but what left over parts can he use from a closed knuckle?
the housing, knuckles, wheel hubs, spindles, bearings, brakes and tie rods are all different. i dont know about the shafts and locking hubs. gears are the same though. |
