Old 12-18-2009, 01:05 AM   #1
hdck07
hdck07's Avatar
Axle
For a 72 K10, daily driver, town and highway driving, very little driving off road...
What axles should I put under it? Did chevrolet make auto locking hubs with a solid front axle for any year or body style? What gear ratio should I be looking for?
Any help or opinions will be welcomed. Thanks
hdck07 is offline   Reply With Quote
Old 12-18-2009, 06:56 AM   #2
Re: Axle
Welcome!!! I`d say look for one with 3.08s if you are staying with 33" or shorter tires and no overdrive.The later 10-bolt front axle had the automatic hub option and those ales swap-in directly.No problem finding a 3.08 one o those,either.I`d only run those with the 33" or less rubber also.
Old 12-18-2009, 10:35 AM   #3
Burt4x4
Burt4x4's Avatar
Re: Axle
I would run D44 8lug front with 14FF rear and 3.73s would give you a bit more torque to the ground. Oh and I would not run auto hubs, yuck! A good set of Warn Premiums are much stronger.
.025c
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
axle, k10, ratio
