damn trannys
so my room mates k5 starts acting strange wont shift out of 1st gear some times it would so im boggled on what it could be i told her to check the tranny fluid first she said it was full so tonight we went out and got a new filter and gasket we were going to change it tomarrow so she goes down the street and calls saying it will only move about 5mph and its in the middle of a main street got in my truck towed it back deside what the hell change the fluid tonight instead i figured it was going to take a while always does teadder toddering all the fluid out of the trans pan so i start unbolting the 16bolts and no fluid get it all down and drained a total of a half a QT out of the hole thing and it was black finished the filter and gasket get it all filled back up and RUNS PERFECT no damage to the trans which is awesome!!!
then to find out the dipstick that i told her to check a couple days ago isnt the original its definaly longer cause it hits the bottom of the pan which could probably explain why it was reading full and no one ever did anything about the shifting |
Master Hater
Re: damn trannys
Glad to hear it worked out, What tranny was it? th350. cause a 700r4 would have been toast.
Re: damn trannys
haha naw it actually was a 700r4 and its still good to go
Re: damn trannys
It may seem good, but it isn't. Time to start saving up for the rebuild.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: damn trannys
ahh it runs exatly how it should its my room mates so if anything comes to be a problem she can have it rebuilt as of now theres nothing wrong with it so we shall see
Re: damn trannys
Re: damn trannys
Boy you dodged a bullet this time usually if your tranny acts up its toast!
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
Still plays with trucks
Re: damn trannys
It will have some seriously burned clutches in there being run that dry. You start burning things up at only a quart low and she was three and a half low. Who knows how hard she pushed it trying to get it to move while very low on fluid.
It is only a matter of time before it goes out completely. Have her start saving for another trans.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
