01-24-2003, 09:02 AM | #1 |
Junkyardjohn, This Pic is for you
John,
I am posting this pic for you, just in case you miss the snow. Jim |
01-24-2003, 10:40 AM | #2 |
NOPE ---- I DONT MISS THAT WHITE STUFF AT ALL. WE GET SNOW HERE ONCE IN A WHILE,?(I'M AT 5000 FEET) BUT IT'S USUALLY GONE BY NOON. I HAD A 9' FISHER SNOW BLADE ON A 67 1 TON WHEN I LIVED IN MICHIGAN. I DO KINDA MISS ALL THE GREEN THOUGH, BUT NOT ENOUGH TO GO BACK. OUT HERE IT'S NO SALT, & ANY TIME THE ROADS ARE DRY (WITCH IS MOST OF THE TIME) I CAN DRIVE MY OLD TRUCKS ALL YEAR LONG. (BACK EAST I HAD TO PUT EM IN THE BARN FOR 4 OR 5 MONTHS AT A TIME)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-24-2003, 12:58 PM | #3 |
Fabricate till you "puke"
I hear you Junkyard John, I doubt that I would miss all that white stuff , if I got away from it! If we got enough of it here in the midwest to "play" in, the wifey would probably complain about the high cost of snowmobiles tho...... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-24-2003, 08:12 PM | #4 |
Plowing snow in the winter is one way to be able to drive one of the trucks that I have. It is not the same as driving in the good weather as it is just back and forth.
We have gotten quite a bit of snow recently so I have had to plow often. But that is Michigan! Jim |
