Old 12-18-2009, 09:41 AM   #1
patrickk1
What sbc water pumps are you guys running, long or short?
Did a quick mockup last night of the sbc in my 1950 3100. I am replacing the waterpump and pulleys and am wondering if i should go to a short water pump. Just a quick look without mounting the front sheet metal yet makes me think a long water pump might not work. I have a firewall with a 2" setback and my motor mounts line right up with the center of the mustang ii crossmember to get clearence on the hei distributor. Found a great deal on a edelbrock victor waterpump but it is a long pump. And yes, I know the pulleys are different for long vs short.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 12-18-2009, 10:37 AM   #2
Richard H.
Spanked once
Richard H.'s Avatar
Re: What sbc water pumps are you guys running, long or short?
Are you gonna run AC with that? Reason I ask is because I do in my 55 and had to go with an electric fan to keep it cool. Short pump.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 12-18-2009, 10:39 AM   #3
patrickk1
I do plan on running A/C.
- Patrick
Old 12-18-2009, 10:51 AM   #4
Richard H.
Spanked once
Richard H.'s Avatar
My pulley fan did not line up for good draw across the radiator ,fan was to low. Plus no good way to shroud it.
Old 12-18-2009, 05:15 PM   #5
OrrieG
OrrieG's Avatar
Long for no particular reason. It does get the fan closer to the radiator. Only accessory bracket so far that is stock is the altenator on passenger side. PS was custom fab, as will be the AC.
OrrieG is offline   Reply With Quote
Old 12-18-2009, 05:44 PM   #6
cajundragger
short with an electric fan. You going to run into rad. clearance issues is you go long IMO.
cajundragger is offline   Reply With Quote
Old 12-19-2009, 12:50 AM   #7
entourageguy
Yellow truck club
entourageguy's Avatar
Long with a rad shroud. 1.5" spacer on flex fan.But I think previous owner set engine back too far as valve covers just clear the stock firewall.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-20-2009, 05:46 PM   #8
poncho_villa
poncho_villa's Avatar
Long water pump, but only because it was easier for the alignment of all the pulleys. I also have an electric fan mounted on the engine side of the rad, so I have no issues there. You can also mount an electric fan on the front of the rad and have it push the air through rather than pull it. That might give you more room.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
