67-72 steel floor in a 60-66
Finally got one, it was a long bed but outlawc and I cut it down to a shortbed. Thanks for your help outlawc!! It fits very good, will have to redrill some holes to bolt it to the bed though. Here are some pics.
Re: 67-72 steel floor in a 60-66
I have mine sitting in storage waiting for the swap. Looks good.... Anything of note that might prevent problems during the swap?
The front bed panel will have to be modified. Since the wood was 3/4 thick, the flange will have to be cut and moved up then welded. I also had to trim this area (in pic) for the sides to fit right. Other than that it wasnt to bad.
Nice work!!!!
Thanks Joe! I need to get some these from mar-k so I can get it bolted up.
GM 58-66 FLEETSIDE INNER WALL REPAIR PANELS |
I'm raising the floor so the front panel is getting modified regardless; I'll watch out for that rear corner now that I'm informed (Thanks!).
I did buy a MarK smooth front panel for the 68 so I might see if it would work as well.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-18-2009 at 06:09 PM. |
I have a 67-72 front panel here and its different at the top in the corners to the 60-66 panels. I thought about using it also.
Did the 67-72 bed floor bolt right to the 60-66 frame stock locations?
Thanks Tony from Norcal |
No it did not. I will have to drill some new holes.
#10 | |
![]() I'm using a 67-72 frame so I should be good to go.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-18-2009 at 10:39 PM. |
Yeah you should be good!
60-66 Nut
![]() ![]() Join Date: Mar 2007
That looks good......now I just need to find one that isn't beat to crap.
#13 |
Yeah i was lucky, mine wasnt too bad. In the back it was beat up, but after the 8 inches were taken out it took out most of the bad area.
#14 |
Hollister, CA.
![]() Join Date: Sep 2006
Looks good man...thanks for share the info !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#15 |
1961 crewcab
looks nice, did the wheel tubs and sides bolt on , or did you have to drill?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#16 | |
Yes, they will bolt right up. No problem Chief. |
#17 |
Here are a few pics. Enjoy!
#18 |
NICE!!
thanks for the pics!!
#19 |
I am going to do this with mine. Thanks for sharing.
#20 | |
![]() Quote:
Looking back, it may have been a bigger job of fitting had it been a fleetside or a longbed. HTH, sam |
#21 |
No problem.
