Old 12-18-2009, 03:50 PM   #1
jay6891
Car Knocker
jay6891's Avatar
Need some opinions please
Well after several years of collecting parts I think that I am ready to tear my truck apart. What I plan on doing is a static drop of 4 and 6. Fitting some 22 for the rear and 18 for the front. Starting on rear end now. Striped down the rear and when I knocked the u bolts out of the trailing arms. They, meaning the arms split at the seams. Old tack welds let go. So I finished them off on the split and got both halves separated. Cleaned them up and welded them solid all the way around. They feel some much more solid and heavier now. My questions are, Should I go ahead and weld some reinforcement plates on there like the factory? Or is it good enough? Also wanting to put a rear sway bar on. Have a CCP rear bar, instructions mount it on bottom of control arms. Looks like it would be a good way to snag on something. Can it be mounted on top for more clearance? Any, if any difference? Putting my c notch in now so the installation of arms will be next. Thanks for any and all help..... Jay
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 12-18-2009, 04:04 PM   #2
SCOTI
SCOTI's Avatar
Re: Need some opinions please
Welding them up was reinforcement enough. Anything more would be added weight w/o much benefit so you're good to go.
I offer one recommendation..... do not do the 18/22 combo. The 2" difference between 18/20 combo's is very noticeable; 4" difference just won't look right.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2009, 04:23 PM   #3
jay6891
Car Knocker
jay6891's Avatar
I have seen our trucks with 18 and 22's. And it looks good, IMO. Granted these were highly~highly modified trucks. And now that I think about it they were always aired out. Hmmm. . . It is just a thought, and I do appreciate your opinion. Keep em coming.
Old 12-18-2009, 06:11 PM   #4
SCOTI
SCOTI's Avatar
Post up pics of an 18/22 combo. I've seen multiple 18/20 combos on here (even have a set); but I haven't seen the 18/22's done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2009, 06:28 PM   #5
64shortc10
64shortc10's Avatar
18's and 22's on this burban!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 12-18-2009, 06:36 PM   #6
jephs422
As long as the truck sits level, 18's and 22's aren't too bad. It has to sit level though. Any rake and it'll accentuate the difference.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 12-18-2009, 07:10 PM   #7
jay6891
Car Knocker
jay6891's Avatar
here is one for sure 18/22.
Old 12-18-2009, 07:11 PM   #8
jay6891
Car Knocker
jay6891's Avatar
What about the rear sway bar? On top of control arms, on bottom of control arms, or no bar at all. Survey Says!!!!
Old 12-18-2009, 08:07 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Tony from Norcal
That's a good looking Burb, but that is not a good example.
Keep in mind that jay6891 is only running a 4/6 drop. Staggered wheel sizes look great on 67-72 when they are slammed. Running an 18/22 with a mild drop is going to make the front wheel look tiny.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-18-2009, 08:14 PM   #10
64shortc10
64shortc10's Avatar
That burban is only lowere 4-6!
Tony from Norcal
Old 12-18-2009, 10:34 PM   #11
SCOTI
SCOTI's Avatar
....here is one for sure 18/22.
Those are 20x8 & 22x10's . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-19-2009, 12:41 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Tony from Norcal
Tony it doesn't matter how much it's lowered as it's not relevant to the conversation. Showing a pic of 61-66 truck/Burb etc does not give a visual of what the OP's truck will look like was the point I was making with my comment. That is an apples to oranges example.
Take a look at this truck I found on an eBay listing. I don't know how much it's lowered, but it will give a good visual of what Scoti referred to. This is an 18/20 combo with a static drop. Imagine how small the front tire/wheel will look if you made the rear wheel 2" bigger.
I'll be the first to point out that the rear tire in this set up isn't tall enough for the amount of drop, but it does give an idea of what we mean.
In the end, tire and wheel choice is all about personal preference. Despite that, I feel compelled to at least try to encourage others based on my experience and mistakes.
Articles-
"Refining Sierra"
Old 12-19-2009, 06:19 PM   #13
jay6891
Car Knocker
jay6891's Avatar
Those are 20/22's? Thought I read on the site that they were 18/22's. See that is why this board is so great...I was led wrong and wouldve been a bit po'ed if I bought the wrong combo. Not that that I would buy without alot of thought. Thanks for the info.
No one got an opinion on the rear sway bar thing?
Old 12-19-2009, 09:20 PM   #14
SCOTI
SCOTI's Avatar
Rear sway bars are simple enough to add after it's driving if they're needed. Put it together & see if you think one is needed first....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
