Old 01-24-2003, 10:13 AM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Performance difference b/w 4.56s and 4.10s???
I have 4.56 gears in my truck and was wondering if I would notice and off line performance drops if I go to 4.10s and a posi? It would also bring my highway rpms down some. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-24-2003, 11:07 AM   #2
Old Chevy Lover
Old Chevy Lover's Avatar
What RPM are you turning on the highway with 4.56's? Last thing I had on the street with a decent motor and gear was a 64' Chevy II.. Had a 327, t350 tranny, 4.11 gear, and running 235/60/14's (which equates to about a 25" tall tire).. turned about 2950 rpm's at 55...
Keith
70 Chevelle Malibu SS Clone 468/Auto
72 C10 SWB 350/Auto
13 Camaro SS/RS 6.2/Auto
Old Chevy Lover is offline   Reply With Quote
Old 01-24-2003, 11:17 AM   #3
HotRod929
HotRod929's Avatar
Old Chevy Lover: about 3500rpm @ 65mph with 30.6" tall tire.
Anyone know if I will notice any difference with the 4.10 gears and a locker?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-24-2003, 11:30 AM   #4
Old Chevy Lover
Here is a website that shows the difference calculations for Rpm, Speed, Tire Height, etc.. you can calculate the difference.
http://www.mrt-wheels.com/formula.html
according to the RPM calc, it would drop you about 300 RPM at the same MPH..
Keith
72 C10 SWB 350/Auto
Old 01-24-2003, 11:50 AM   #5
HotRod929
HotRod929's Avatar
Im actually more worried about off the line performance. Will it drop a lot with 4.10s?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 01-24-2003, 12:00 PM   #6
Old Chevy Lover
I think it kind of depends on what type of a motor that you have put together. If its basically stock, then you will not have that intial 'jump' off of the line like you do now. But then again, if your running an open rearend now, and have any wheel spin off of the line, then going with the 4.10 and a posi will launch you better/faster than you are now. I think the biggest thing you will notice is that it will take a little longer to wind out the motor when your going through the gears. It doesn't neccessarily mean its that much slower, just the motor having to labor a little harder.
In my 72 Nova drag car, I went from a 4.56 to a 5.38 gear (have 33" tall slicks) and really didn't notice a big difference like I thought I would out of the hole. Biggest thing was getting down the track (1/8th mile), the motor wound out a lot quicker, and I picked up a little bit of time because it wasn't having to work as hard to move the car.
Keith
72 C10 SWB 350/Auto
Old 01-25-2003, 01:05 PM   #7
sakohntr
sakohntr's Avatar
The posi is irrelevant to this question. You will notice a difference in acceleration. I would much rather have a car (or truck) that went to 100mph in a short period of time than a car that will top out at 140. No engine can make up for a lack of steep gearing.. good luck
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 01-25-2003, 01:39 PM   #8
bigjimzlll
bigjimzlll's Avatar
its all about your usable rpm range..if your motor stops making power at 4500 rpm, the higher gears(4.10s) will actually help performance..allowing the motor to be in its usable rpm range for a longer time..the lower your max torque is the higher gear you will need..the higher up in the rpm range your max torque(HP) is the lower gear you will need ..of course this has to take into account the track your running on..1/8 or 1/4 mile.. right now your probably running out of usable power at the 800 foot mark in the 1/4(depending on your engine)..either build the engine to rev and make power up to 7000 rpm, or stick some higher gears in.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
