Old 12-18-2009, 10:30 PM   #1
damnyankee36
damnyankee36's Avatar
Insulating Roof
In my quest to get my cab as quiet as possible, I've been thinking about filling the area with some sort of insulating material between the ceiling and roof panels on my 66.
Originally, I thought about strategically drilling holes and squirt in some expanding foam to fill the space. Someone thought that might cause a future rust problem if the foam trapped condensation. I can see the possibility of that. However, here in New Mexico, that might not be much of an issue.
Then, I thought about Vermiculite. I just need to figure a good way to seal the A and C pillar areas to keep it it from spilling out. I can flip the cab upside down to fill the space.
Has anybody else tried to insulate this area?
damnyankee36 is offline   Reply With Quote
Old 12-18-2009, 11:38 PM   #2
tommys66
Re: Insulating Roof
I did just as you suggested. I drilled holes and filled with expanding foam. Not sure of the outcome, I have yet to reinstall the cab. I do not see this as being a problem. This foam is basically the same as the OEM foam used on the late model roof skins. I think it will work good.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 12-19-2009, 12:34 AM   #3
daverod
SSN 706
daverod's Avatar
Re: Insulating Roof
I put two cans in the dome light hole. Got rid of the a$$ spot the corn fed made. The foam is closed cell I doubt if it would hold water.
daverod is offline   Reply With Quote
