edelbrock carb question
Just changed my intake and carb to a edelbrock performer and it has an electric choke-were is the best place to tie into to get power for the electric choke?I am new to these chevys and have no clue what to look for or tie into -Thanks for the help-
also what should i set the timing at? |
huh ???
Re: edelbrock carb question
You need to tap into keyed 12 volt for the choke. I would run a wire into the fuse box and find a circuit thet only gets power when the key is in the run position...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
I ran mine off the winshield wiper motor.
i ran moine off of the oil pressure switch. that way if it loses power it will close the choke and kill the engine.
#5 | |
I ran my last one off a keyed 12V signal as stated, you want to be able to turn the key on, wait a sec for the choke to adjust (especially in cold weather) and then crank...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
it needs to go to a keyed 12 volt source off the fuse block. hacking into and taking power from other stuff is never a good idea. you guys are asking for electrical problems
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
