Old 12-19-2009, 11:17 AM   #1
78-5.3
78-5.3's Avatar
4 link !
does anyone now where i can buy a 4 -link kit with the 4 bars rod ends and brackets!!! that i could fit to my truck im not interested in the air ride suspension ! this one from brothers is what im looking for but i want the 4 bars to be on the inside of the rail anyone personal installed one of these kits ?? pics ideas i want the install it on the inside for a massive tire !!!
78-5.3 is offline   Reply With Quote
Old 12-19-2009, 11:38 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: 4 link !
They call that a 4-bar suspension to keep it distinguished from a drag car 4-link.
The 4-bars are common hot rod stuff so I would do some searching for hot rod parts vendors.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-19-2009, 11:50 AM   #3
68 TT
68 TT's Avatar
Re: 4 link !
The difference is the 4-bar has no alternative mounting points for the four equal size bars and they are parallel with each other and the driveshaft plus it uses a panhard bar to locate the rear end side to side. Really simple to install and set up.
The drag car 4-link uses different length bars top & bottom and each bar mounting point has several alternative locations so you can change the characteristics of the suspension system. It is also located side to side with a diagonal link that is connected from the front on one side to the rear on the other. It does not allow for much body roll at all.
There is a version of the 4-bar called a triangulated 4-link that uses angled upper & lower bars that point inward at the front in different locations top & bottom that does not need a panhard bar. This is what GM used from 64 to 88 on A-body & G-body Chevelle & Monte Carlos and all their clones plus a few other cars. Quite a bit of chassis engineering math involved in setting it up to work well but when done right it is very nice.
Old 12-19-2009, 11:55 AM   #4
68 TT
68 TT's Avatar
Re: 4 link !
It wouldn't be any big deal to put it all on the inside of the frame rail. It would just need some boxing of the frame rails in the mount point areas to give you somewhere to bolt it up. A simple rectangular tube crossmember could take care of this too. A generic application hot rod parts package would probably do it this way.
Old 12-19-2009, 12:01 PM   #5
78-5.3
78-5.3's Avatar
Re: 4 link !
ive seen them @ chasss online vendors and hotrod places lke chris alston chassisworks but im looking for something that i can buy that will work with the trucks dont mind fabbing it some after buyng it but im looking for the right parts to buy
IE - BAR LENGTH FROM TUBE BRACKETS TO BRACKETS ON FRAME
there must be a set up out there like brothers that will work and require minamal work to fit a c10 truck ! a 4 link or 4 bar setup like this !!
Old 12-19-2009, 01:07 PM   #6
78-5.3
78-5.3's Avatar
Re: 4 link !
CHRS ALSTON CHASSISWORKS HAS A KIT!!! they also have a 74 c10 in there how to section!! the kit is called PKG U $789 gets you most of whats needed to make it a 4 bar with lots of ride height options i will get this kit in the spring!! couldnt cut and paste the pic for some reason its in the chasss work catalog 16
page approx 133
Old 12-19-2009, 01:47 PM   #7
3r!c84
Badass
3r!c84's Avatar
Re: 4 link !
you can buy all the hard wear and make it your self too?
like what all the 4x4 guys do
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-19-2009, 10:15 PM   #8
gmclowsierra
Re: 4 link !
the reason the drag race kits have adjustable holes in them is to adjust for track conditions. you can also change the instant center oin the car so it will hook better. either kit will work but the adjustable one is better. a little harder to setup but not much. are you going to drag race this thing or just street drive it?
gmclowsierra is offline   Reply With Quote
Old 12-20-2009, 04:49 AM   #9
team39763
Re: 4 link !
What about that KP 4link system? I had looked into it a while back. They have a bolt on setup for our trucks and I'm sure you could modify them to fit inside the frame. I don't have the link anymore, but I'm sure somebody around here has heard of it or looked into it.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 12-20-2009, 10:34 AM   #10
68 TT
68 TT's Avatar
Re: 4 link !
KP is a Chassisworks sub-brand. Their catalog is on the Chris Alston web site. Lots of neat stuff for our trucks.
http://www.cachassisworks.com/cac_catalogs.html
Old 12-20-2009, 10:51 AM   #11
78-5.3
78-5.3's Avatar
Re: 4 link !
this one here????
i think you must run the canterlever airbag system with this!!!
Old 12-20-2009, 11:01 AM   #12
68 TT
68 TT's Avatar
Re: 4 link !
page approx 133
Are you talking about the Battle Cruiser 4-link package?
What exactly are your plans for using this truck? A drag race 4-link package like that with all spherical rod ends will not last long on the street and is kind of noisy.
If this is meant to be a street truck I would go with something that has polyurethane rod ends and not spherical bearings.
If you are going to run that 9" rear end then a triangulated 4-link like is on pg 14 of the KP Components catalog will work great. Add in a set of coil over shocks like on pg 33 of the VariShock catalog and you are set. About $940 but well worth it to have poly bushings instead of spherical bearings.
Old 12-20-2009, 11:06 AM   #13
68 TT
68 TT's Avatar
Re: 4 link !
this one here????
Those look like non-adjustable coil over shock mounts on the back.
Old 12-20-2009, 11:24 AM   #14
78-5.3
78-5.3's Avatar
Re: 4 link !
no i dont wanna race it i just wanna decent suspension and be able to run a big tire under it!!! with out fouling suspension conponents s that why wanna run in board suspension
Old 12-20-2009, 01:47 PM   #15
68 TT
68 TT's Avatar
Re: 4 link !
The triangulated 4-link is easy to mount on the inside of the frame rails so it will give you room for a huge tire close to 18" wide, maybe more depending on the sidewall flex and your ride height.
How big is a big tire to you? You can run a 325/50-15 drag radial on a stock truck arm suspension with a lot of clearance. I ran them on my 67 C-10.
My 78 K20 has 16" between the leaf and the inside edge of the fender lip so there is enough room for a 14" wide, tall sidewall tire with some room for sidewall flex without damage to the tire even with the truck in the weeds.
Old 12-20-2009, 06:02 PM   #16
rigon4
rigon4's Avatar
Re: 4 link !
If you are just looking to run a big tire under the truck im running a 29-15-15 MT on my truck with stock suspension
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 12-20-2009, 07:27 PM   #17
Pyrotechnic
Pyrotechnic's Avatar
Re: 4 link !
It seems like the 4 bar setups cater more to the people who do air ride. The bars are parallel so it keeps the pinion angle constant, whether slammed or lifted.
A 4 link will not have the links parallel to each other. Instead they are angled together, which helps weight transfer and helps the tire bite better. A drag car 4 link can be adjusted to give more or less bite to give the best launch.
I would much rather have a 4 link that's geared toward traction, even if I wasn't racing.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-21-2009, 09:11 AM   #18
78-5.3
78-5.3's Avatar
Re: 4 link !
i like this
http://www.summitracing.com/parts/ART-ARS13500/
Old 12-21-2009, 12:29 PM   #19
68 TT
68 TT's Avatar
Re: 4 link !
Looks good. Don't forget with that you will need an air compressor, storage tank & control system to manage the air bags.
I guess you could just set the pressure you want at home with the shop air source and hope it didn't have a slow leak.
A small on-board air compressor could take car of that though or if in-field adjustments were needed.
Old 12-21-2009, 02:00 PM   #20
78-5.3
78-5.3's Avatar
Re: 4 link !
SEAMs cheap in price hopefully not in quailty !! i think that would be easy to install i wonder if it been done by anyone here???
Old 12-21-2009, 02:16 PM   #21
68 TT
68 TT's Avatar
Re: 4 link !
It looks just like the KP Components triangulated 4-link universal kit but with air bags. The KP kit is only $399 so if you added a set of budget coil over shocks & mounts you could be less expensive and not have the hassle of air suspension to deal with.
You could even go with regular shocks and coil springs from a truck arm 67-72 application for a bunch less money.
Old 12-21-2009, 03:01 PM   #22
78-5.3
78-5.3's Avatar
Re: 4 link !
i tried looking for the KP CATaloge on the pages you said i couldnt find them!
Old 12-21-2009, 03:13 PM   #23
68 TT
68 TT's Avatar
Re: 4 link !
http://www.cachassisworks.com/downlo..._VOL_3_WEB.pdf
pg 14 at the bottom of the page
Old 12-21-2009, 08:45 PM   #24
78-5.3
78-5.3's Avatar
Re: 4 link !
yeah with the
Full-Height Lower Shock Mounts
pn# 6224 20-position mounts and brackets $75.00
and
Round-Tube Shock-Mount Kit
pn# 6217 round-tube shock Mounts and hardware $25.00
what shock would be best !????
Old 12-21-2009, 08:51 PM   #25
68 TT
68 TT's Avatar
Re: 4 link !
yeah with the
and
The popular one with leaf spring drag cars is the Rancho RS9000X adjustable one. About $90 each.
http://www.calvertracing.com/rancho.php
I plan on getting a set to replace the generic adjustable ones on my car now.
I have heard good things about the Edelbrock Performer IAS shocks but have never used them myself.
