01-24-2003, 11:53 AM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
Ring & Pinion Question???
I have a Dana 60 with 4.56 gears and I want to go with 4.10s. My question is that can I just get a 4.10 ring & pinion set and have someone just put it in or is there something else involved? I was looking around and saw that 4.56 gears were for a 4 series carrier but the 4.10s were for a 3 series carrier. What does this mean? Thanks
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
01-24-2003, 02:45 PM | #2 |
67-72 Addict!
3:73 and 4:10 are for 4 series.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-24-2003, 03:05 PM | #3 |
Then whats the deal with this ebay auction.
http://cgi.ebay.com/ebaymotors/ws/eB...400634598&rd=1 HotRod
01-24-2003, 03:14 PM | #4 |
What do you mean? He has two different colors for the low 60 (3.54-4.30 and 4.57-5.13) You win the auction, you get your choice of gears. If your carrier doesn't fit, (and if you have 4.57 it won't work on 4.10) you will need to get another.
01-24-2003, 03:20 PM | #5 |
thats what im trying to understand. I have 4.57s and I want 4.10s...do I need to get a different carrier to put the 4.10s in?
HotROd
01-24-2003, 03:25 PM | #6 |
"Ochre Ogre"
yes
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
01-24-2003, 03:32 PM | #7 |
thanks
HotRod
01-24-2003, 06:27 PM | #8 |
Used to have a truck
One thing I dont understand about dana 60's is that everywhere I see parts for them mentioned they have 1965 as being the first date of manufacture. Yet the differential in my truck is date stamped 1962 as are the ring and pinion in the rear end I pulled that dif from. I dont know what the rear end came from as I got it from a pile in the junkyard. Does anyone know what year they started making Dana 60's ?
No truck :-( |
01-25-2003, 04:45 PM | #9 |
Actually just to be confusing, Richmond Gear offers an aftermarket 4.10 that apparently uses the 4.56 (series 4) carrier. The part # they give for it in the Summit Racing Catalog is RMG-6900521. The catalog says it has a thin ring gear (9.760" diameter) as opposed to the 9.875" of the normal 4.10 gear (Part # RMG-7900111).
I don't know anything about it other than what's listed in the catalog-- I've never seen or used one of these, and in general I favor genuine Dana gears over any aftermarket ones I've seen. But maybe using one of these aftermarket thin sets would save you the cost of switching carriers? If someone else has actually used them, they might be able to provide more info. On the other hand, if you want to get normal 4.10's and just need a series 3 open carrier I've got a used one in good condition you can have for $5 plus shipping if you can't find one locally. Last edited by williso; 01-25-2003 at 04:56 PM. |
01-25-2003, 05:50 PM | #10 |
I run a Richmond "thick" gear in my Jimmy. It allows for 4.10 gears on the 12 bolt 3 series carrier. They have worked fine. I have never looked at Dana gearsets for sale to know they offered it, but it is a good solution IMO.
