Looking for input, experience from "bag" guys
Considering baggin my burb with a BBC (507 Cad) using Dominator 2600 front and rear any pros/cons. Appreciate ya'll sharin any experiences you encountered. I'm not lookin ta hop up and down just want a low smooth ride.Thanks!
Re: Looking for input, experience from "bag" guys
Those should work just fine.
3DrDwn--the 'burb not the band
Plan on using a pressure switch set to cut out no lower than 145 psi. My experience with BBC (3 454's 69,89sq,92) it needs to have just over 110-120 PSI to "pop" up and slightly higher to "top out". once it's up you can drop to a little lower pressure depending on your preferred ride height and spring rate.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
Big block are heavy is there a way to get an 8" bag up front?
Adam M STX Designs Motorcycles | Choppers | Hotrods |
Its my understanding 2600's are 8" just wondering if I would encounter clearance issues.And hoping for somewhere around a 3.5-5 drop or ride height am I going to be in that range?
how bout some pics. you'll most likely have to cut the bump stop out.
nickle and dime |
