Old 05-20-2002, 09:17 PM   #1
brad2
Post Will my truck fit on a tow dolly
I need to rescue my truck from a shop where it has sat for a year with next to no work on it. Will the front fit on a tow dolly? If not how about some opinions on tow bars.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 05-20-2002, 09:24 PM   #2
ebfabman
Post
Hey Brad, I'll be in OKC in a week or so. Need some help?
ebfabman is offline   Reply With Quote
Old 05-20-2002, 09:25 PM   #3
bluestreak52
Post
Yes if you get the right dolly you need a wild dolly I have towed my truck on a smaller dolly but only short distance
bluestreak52 is offline   Reply With Quote
Old 05-20-2002, 10:43 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I have yet to see a dolly for rent that is wide enough. Don't even bother with U-Haul.
A tow bar is one of the best things you can own IMO.
I got one at Wall Mart (R.V. section) for 100 bucks, then towed my '69 SWB from tx to Ohio behind the moving van. No trouble at all.
Then, this past March, Longhorn Jeff and I went to Pa, and pulled my one ton Longhorn behind his K/5 blazer 428 miles to get it here. That one was kinda scarey, but no real problems.
The bar from Wally's World is rated at like 3000 pounds or something wimpy like that. But, since I was removing bumper bolts, and bolting this thing directly to the frame instead of in holes drilled in the bumper (as per instructions on tow bar) I gambled, and won.
If it is just across town, you could always take the side roads and use a chain.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-20-2002, 10:52 PM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Post
I used the same tow bar as longhorn to tow the Blazer home and it worked fine. Just tie the steering wheel down and remove the drive shaft. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer New project
1995 K1500 Sub(Mommas car)
1989 VW Golf(Beater)
Will be the daughters car if she will pay her insurance! Ha!
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 05-20-2002, 10:55 PM   #6
Longhorn Man
Post
Why you tie the wheel? If you do that, it will be more likely to push the tow vehicle in a turn and jack knife.
I towed with tow bars in the army for almost 8 years, and went to recovery school. One guy was almost killed when he did that on a hummer. Cockey SGT thought he knew best.
You wanna leave the wheel loose, so the towed vehicle can follow through the turn by the tow vehicle.
Columbus Ohio
Old 05-20-2002, 11:04 PM   #7
brad2
Post
Eb it's in Amarillo...thats about four hours each way.
I knew I would have to drop the driveshaft but was under the impression that the steering wheel should be left free.
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 05-20-2002, 11:11 PM   #8
Alvin
Never Done?
Alvin's Avatar
Post
I'm assuming it is possible to tow a rolling chassis with the tow bar? Will it matter that it doesn't have any lights or anything? I may need to find a way to get one home about a 310 mile trip. Thanks,
- Adam L. Vogel
University of Cincinnati
White 68 GMC short, fleet, 350/TH350, 67-8 chevy grille, 5-lugs, front power disc brakes, power steering, a/c (not complete yet)
My truck site
IM= newt0
[This message has been edited by Alvin (edited May 20, 2002).]
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 05-20-2002, 11:30 PM   #9
Joachim
Carolina Cajun
Arrow
I used a UHaul 4/wheel carrier to bring my 66 C10 project home. It was a perfect fit. Rear wheels cleared the back ramp by about 6 inches and had 2 or 3 inches on either side of the ramps. Took a long time to get it up on the dolly using a cable hoist. But it pulled with no problems.
Joe
The Carolina Cajun, almost famous in North Carolina since 1989!
Driving a 68 & Restoring a 66.
Lookin' for Rochester 1bbl & 2bbl carbs!!
Lookin' for Rochester Manual 1bbl & 2bbl carbs!!
Concord, NC & Ponchatoula, LA
Joachim is offline   Reply With Quote
Old 05-20-2002, 11:39 PM   #10
Longhorn Man
Post
As for the tail lights, I used a trailer light kit once, bolted the lights to the rear bumper (tape would do if you have a pretty bumper back there) and ran the wires up to the tow vehicle.
The other time, I fabbed a harness to go from the tow vehicle, to the tail light harness on the towed vehicle. You won't need a bettery in the towed vehicle, just good bulbs and harness. Just unplug it grom the firewall, and use crimp on connectors to plug each wire in. You can use schematics, or just trial and eror. All you need is tail lights, and the laft and right blinker...with the blinkers wired, the brake lights will be automatic. Works out pretty darned cool.
Columbus Ohio
Old 05-21-2002, 08:35 AM   #11
Erl
Erl's Avatar
Post
Get the Uhaul car carrier for $60 per day and be done with it. They will tell you a truck will not fit, but it will no problem. I pulled a 3/4 4x4 from Amarillo to Dallas at 75MPH with a 1 ton van. Do not take a chance on causing a wreck, the cost is too great.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 05-21-2002, 09:25 AM   #12
ckhd
ckhd's Avatar
Post
I used a U-haul tow dolly to get the '68 (a 3/4-ton 4-wheel drive) from L.A. to Eastern AZ. They WILL fit on U-haul's narrower tow dolly - providing your tires aren't too wide. I insisted at Uhaul that they give me the wider tow dolly, but they couldn't make the lights work on the one they had, so they gave me a narrow one... which I had to fix the lights on anyway.
I took an extra set of narrow tires to put on the '68.
I also had to mislead uhaul. When I told them I was towing a '68 K20 with a '92 K20, they said the '92 wasn't heavy enough, so I called back and said I was hauling a '92 K20 with a '68 K20 and they let it go.
Bowen
'68 K20 fleet
'69 K10 swb fleet
'72 C10 lwb step
'72 K10 Suburban
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 05-21-2002, 09:58 AM   #13
1ToBjimmyk5
Post
I put my 71 blazer on a u-haul car transport(u-haul term). I have 31x10.5 tires on the truck was very tight but worked great. For a trip of more that 3 hours I would use the trailer. btw U-haul said the truck was too heavy to tow with anything other that a 1 ton truck. I used my e350 ( I know, towing a chevy with a ford is a NO-NO) and it worked great
1971 Chevy Blazer(looks like Jimmy),1988 Ford E350 Van,2001 Nissan Sentra(Wife), 1993 Nissan Sentra (to/from work),1985 Dixie (boat) with a big Johnson,And I want my 1970 Buick Conv. back!!!!
Centreville,VA
1ToBjimmyk5 is offline   Reply With Quote
Old 05-21-2002, 10:39 AM   #14
1-PU70
1-PU70's Avatar
Post
If you flat tow or use a tow dolly the truck you are towing must be registered. If any wheels of the towed truck is touching the ground it must be registered. Something to think about.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 05-21-2002, 10:56 AM   #15
Longhorn Man
Post
In most staes, that is true, I know in PA, it is not required.
If TX says you need tags, you can get the one way tag for 5 bucks if memory serves.
Columbus Ohio
Old 05-21-2002, 11:49 PM   #16
brad2
Post
So even though u-haul will say it won't fit......it will?
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 05-21-2002, 11:53 PM   #17
Alexis
Member since 2000
Alexis's Avatar
Post
u-haul, lol, what opinion do they have that the point they call it U-haul, the local one around here dont do anything except sit around a look at the line get big.
Britney: 1970 2wd K/5 Blazer (gots to go)
Jessica: 1967 2wd SWB (not yet decided on furture)
Helga: 1972 4x4 3/4ton LWB (going to go too)
AIM:Alexmart1
Mountain View, Cali
Alexis is offline   Reply With Quote
Old 05-22-2002, 07:31 AM   #18
Dan69 step
Post
You can dolly it no problem! I have my own and have dollied all of my trucks at one time or another. Have even towed a couple of 1 ton fords before.
69 short step
68 50th Anniversary Gold/ White lwb
72 2wd Blazer
63 Studebaker Avanti
85 Avanti
66 Studebaker Cruiser
49 Studebaker pickup
3-49 Studebaker 1 1/2 truck
94 White/ GMC coe (cabin hauler)
95 chev
2015 chev Duramax 2500
Dan69 step is offline   Reply With Quote
Old 05-22-2002, 07:48 AM   #19
1ToBjimmyk5
Post
what size tires do you have on it?
Centreville,VA
Old 05-22-2002, 07:46 PM   #20
Dean23
68cst_ss490
Dean23's Avatar
Post
I work for uhaul as a mechanic. Using a tow dolly is a tight fit with one of the trucks. You are better off renting an auto transport form them. The auto trans has 4 wheel disc brakes and you can pull rthem witha normal 1/2 ton. I used a company truck to bring in the 79 we scrapped and i was drivng 75-80 no problem with a 93 gmc 3500 witha 454 in it. They pull better than the ford diesels.
Dean
edmonton,canada
68 c10, project in works,350, th350, plain jane.
SLOW AND STEADY GETS THE PANELS READY
http://communities.msn.ca/MyChevytruckpage
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 05-22-2002, 10:03 PM   #21
brad2
Post
Dean23 is the transport a form of a dolly or a trailer? My concern is that my tow vehicle is a lowered truck with 20 inch wheels on the back. It won't handle the tongue weight of a trailer.
74 swb
71 2wd Jimmy
82 2wd Blazer
Old 05-22-2002, 10:12 PM   #22
Longhorn Man
Post
And that trailer weighs as much as some smaller cars. Right at one ton..2000 POUNDS!!!
Columbus Ohio
Old 05-23-2002, 11:46 PM   #23
Joachim
Carolina Cajun
Exclamation
The transport is a full trailer. The vehicle being towed will be completely off the ground. Only the transport/trailer wheels will be on the road, 4 of them. If your towing vehicle will not handle the trailer, I doubt it will handle the two wheel dolly very well either. The transport is far eaiser and safer. Just my thoughts.
Joe
