nova front clip springs
Ok so I have a 56 chevy p/u with a 77 nova clip. im probably going to use my 350 smallblock with a 4L60 trans. My question is what springs to use. Stock nova v8, camaro v8, Z28 springs or something aftermarket. It has a 15/16 swaybar and I want it to ride good, but also handle a little like a sports car. Im just not sure what to use, so i thought maybe someone here could give me some insight.
#2 | |
Re: nova front clip springs
Happy to be here
![]() Join Date: Mar 2000
Scoti is on the right track, but I would suggest getting it mocked up before making a final decision.
If you have the stock Nova springs, build the truck around that. If you need a different spring rate, it's easy enough to change them later.
