Has anybody installed this before?
Did a search on this but didn't seem to find anything. Has anybody installed the Wide Ride IFS kit from no limit engineering? Looks like a great set up and for the price it seems even better. I was searching tubular control arms and found this. Any experience or thoughts about this? Here's the link http://nolimit.net/prodinfo.asp?number=WRIFS-C
#2 | |
Re: Has anybody installed this before?
If you already have discs, Porterbuilts 'Dropmember' is the better choice: just as low or lower, 90% bolt-in installation, re-uses existing truck a-arms or aftermarket tubular arms, uses 12" truck disc brakes (or truck alternatives), & R&P steering.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-20-2009 at 01:07 AM. |
![]() Join Date: Jul 2006
I think there is a write-up on this in the latest Classic Trucks mag but it was on a 55?ish pickup. Same components though. It looks great, but I'm not sure that there is an advantage over some of the other crossmembers and control arm set-ups (porterbuilt for example). The way the lower arms are set way back has a weird look to me. And this is a design for multiple applications, not just 67-72. $2300...no thank you. Just my .02.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Happy to be here
![]() Join Date: Mar 2000
If your looking for a IFS that can be custom tuned to your application, check out www.scottshotrods.com. They are a Forum Vendor and frequent this forum.
It's not a bolt in, but in my research they offer the widest range of options for a custom designed IFS. It's not the cheapest, but it's not built from left over Mustang II parts either. ![]()
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-20-2009 at 12:44 PM. |
Cool, thanks for the link. I think I've looked at that before but thought I was going to stay stock but now but considering dropmember with tubular control arms with the rack set up.
Talk to nate he can do coil overs instead of bags or has a c4 one which uses c4 corvette parts.
#7 | |
#8 | |
