Old 12-20-2009, 06:48 AM   #1
Shamil
Shamil's Avatar
body mount
did someone ever mount a 88-89 truck body,long bed to a 73-87 frame?
is it doable?
a friend is asking; he need to know before he start his project
Shamil is offline   Reply With Quote
Old 12-20-2009, 09:43 AM   #2
b454rat
Re: body mount
Iv'e seen it done, not sure exactly what needs to be changed. Body mounts at least....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-20-2009, 11:03 AM   #3
78-5.3
78-5.3's Avatar
Re: body mount
hmmm i would wanna go the other way 73-87 on a 88-99
78-5.3 is offline   Reply With Quote
Old 12-20-2009, 11:09 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Re: body mount
Is this 4x4 or 2-wd?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-20-2009, 04:13 PM   #5
Shamil
Shamil's Avatar
Re: body mount
it is 4x4
Old 12-21-2009, 01:17 PM   #6
68 TT
68 TT's Avatar
Re: body mount
Originally Posted by Shamil View Post
it is 4x4
Do you want the solid front axle in place of the IFS or are you making a 2-wd new body style truck a 4x4 with this swap?
You may run into some clearance issues like when putting a 67-72 body onto a 73-87 frame but it will probably just take removing the body mount brackets off the square body frame and installing them onto the new body style frame. A 2" or 3" body lift might be needed depending on the frame contours.
I don't know how wide the new body style frame is but you might get lucky and be able to simply swap out the mounts. You may have to do some heavy fab work to build new body mount stands though if the width is too far off.
Old 12-21-2009, 04:31 PM   #7
Shamil
Shamil's Avatar
Re: body mount
thanks you guys, i'll pass your comments to my friend...
