![]() Join Date: Jan 2007
Closed Knuckle DANA 44 disk brakes
What is the best and most cost effective way to put disk brakes on a closed Knuckle DANA 44 front Axle? The Axles are stock now.
T HANKS
Re: Closed Knuckle DANA 44 disk brakes
get a set of open knuckles you can pick up a complete dana 44 or gm 10 bolt for $100 and have all the parts you need to interchange.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
The easiest imo is to just swap the axle.
Blackbirds Customs has a disc brake conversion kit, but it would be cheaper and easier to get another axle that has discs already.
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
![]() Join Date: Feb 2000
I gotta agree you ought to just swap in an open knuckle axle - the decreased turning radius you gain will be a huge additional benefit.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
ditto, I did it this way...
all chevy solid axles will work, BUT you are going to have to swap brake lines, and add a proportioning valve for the disc brakes...maybe even a new MC... i'm not finished with my conversion yet.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 12-20-2009 at 11:21 AM. |
Thanks for the info.I got An 1966 4 wheel bare c
hassis and body just trying to find a starting point.
I just have one word of advise to offer,swapanotherwholeaxleastheothershavesuggested.
I really want to build one of those.
![]() Join Date: May 2007
Make sure the gear ratio is the same if you swap the axle.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Jul 2009
Ditto on the open knuckle swap. In addition to the tighter turn radius mentioned before they are easier to maintain than the closed knuckle. You can find your part here:
Pull-A-Part |
| Bookmarks |
