12-20-2009, 02:12 PM | #1 |
Cab corner, rocker panel seam?
I just wanted to see what all you guys have been doing with this seam. I know some are welding it shut and others just leave it alone. I personal like the look of this seam. The reason I am asking is because I plan on leaving it visable. If you leave it are you guys putting any sealer on the back side of the pinch weld to seal of the inside or just leaving it alone? I know it would be hard to get in there and seal/caulk it.
I just want to see what all you guys have done and see what ideas any of you have. Since there are some very inovative people on this board!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
12-20-2009, 02:59 PM | #2 |
Re: Cab corner, rocker panel seam?
Leave the seam, I dont think I would even seall it up. Not sure of your weather, but up hear I could see that being a huge issue with a little moisture being stuck behind the seam.
67- 72 Parts collecter |
12-20-2009, 03:55 PM | #3 |
seal it or you will be doing it again. They were sealed from factory.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-20-2009, 04:03 PM | #4 |
71 super, was it sealed on the inside or outside?
12-20-2009, 04:35 PM | #5 |
run the seam sealer across the top of your rocker and down the seam of the rocker/cab. all the way so moisture doesn't go behind the rocker.
and outside.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 Last edited by thelonerife; 12-20-2009 at 04:36 PM. |
12-20-2009, 05:22 PM | #6 |
They were sealed as stated from the factory and so was the cab corner. Not very well they just kind of dumped the sealer in real sloppy. Since most people aren't treating these trucks like they use to. If you do either way should be Ok. If you weld it up it can still get corrosion from under. I personally just prefer treating the metal and just using seam sealer. Welding them up looks like it was filled in with bondo. Spray them on the inside with some panel wax
12-20-2009, 06:45 PM | #7 |
OK, great thanks guys for your comments. I have already sprayed everything to death with primer/paint on the inside. The other thing that I remind myself of, is that the truck is not going to be driven in snow/salt and off road anymore either. I know rain and wash water will get in but will be in the heated garage to hopefully help dry it out. Also it will be taken care of a lot better than it was in its first life.
12-20-2009, 07:40 PM | #8 |
As stated before, seal it from the outside, and if the door is off you can spray 3m undercoat or similar in through the hole all the way back. Harold
12-20-2009, 09:09 PM | #9 |
What product is this exactly and where do you get it? I have heard about it many times. I have heard it called body wax too. I asked at the paint supply houses and they look at me funny. I would like to find a source for the product and the application wand. Any info to share would be great!
Brett |
12-20-2009, 09:47 PM | #10 |
me too
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
12-20-2009, 09:56 PM | #11 |
seal it other wise it will rust out use seam selear before you prime it or weld it up and smooth it out thats what i did on mine
12-20-2009, 10:28 PM | #12 |
Still livin the "dream" in '54
I don't know if I would weld up the seam, but if you wanted to run a little urethane sealer in the crack that would be fine.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
12-20-2009, 11:25 PM | #13 |
We have the wax stuff where I work (MB Littleton), but it's Mercedes so I bet it's expensive.
I think all the other Euro rides use it, maybe try VW?? It does stay put in the body voids.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-20-2009 at 11:26 PM. |
01-13-2010, 12:35 PM | #14 |
Why wouldn't you weld it?
1968 LWB C20 / AC / Wood Bed |
01-13-2010, 01:39 PM | #15 |
The Eastwood Company carries the wax material and the guns to apply it (called Heavy Duty Anti Rust). Another wax material you might consider is LPS3 that normally can be found in a aerosol can.
I had problems with the lower rear corner of the rocker panel fitting and had to cut it back to fit and it was just easer to weld it up for me. You can see some of the unusual fitting of my rocker panel on my build thread.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
01-13-2010, 01:40 PM | #16 |
Oops...
Thanks, Bruce, for answering my question while I was typing it!
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 01-13-2010 at 01:42 PM. |
01-13-2010, 10:24 PM | #17 | |
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
01-26-2010, 07:28 PM | #18 |
how do seal the seam without covering it?
01-26-2010, 07:42 PM | #19 | |
If you want to use the product Gm uses its Wurth product 0892 0791 Any wurth dealer sells it. We do. Any AUto Paint supply house SHOULD no what it is. |
01-26-2010, 09:30 PM | #20 |
Definitely seal it up. Been there and replaced that on a truck that was not done properly. NAPA has the spray on sealers and bedliner kits that work too if you can't find anyone else.
Better to keep your mouth shut and let everyone think you are an idiot, than to open your mouth and remove all doubt. Mark Twain |
05-17-2021, 06:32 PM | #21 |
Doing some research and dragging this thread of form the past, but I am getting ready to do the rockers and have this same question. How do you seal that seam from the outside without covering / smoothing out that seam.
Also what is the best way to do the front seam? I know that one is a little less cosmetic but still would like to do it correctly. |
