Transmission Swap; 700r4 to sm465
I have an '84 chevy k10 (4x4) with a 700r4 that is pretty much done. And not that it matters but its a 305 right now but i have the 350 im dropping in it already which is what the Sm465 would be going onto. Instead of spending money on something I dont want (an automatic transmission) I'd rather just swap it out for a manual (sm465) because to me if im going to be driving an old truck it only right for it to be a manual. I just have a few gaps im missing and after searching i know people have done this swap I just cant find exactly what i want.
List of what I know i need SM465 with bellhousing flywheel pilot bearing clutch pedal and linkage Now what i dont know is.. Will I need a different crossmember Im guessing a different transfer case depends on what spline mine is? Will I need a different (taller) transmission tunnel.. Thanks!! Last edited by bikes&bowties; 12-20-2009 at 06:41 PM. |
Re: Transmission Swap; 700r4 to sm465
Will I need a different crossmember?
This depends on what t-case your gonna use. I have the same year truck, and did the same thing as you. I used a 205 from an 86 1 ton. IIRC the stock flat crossmember would work, but you need to lower the crossmember and raise the t-case. I think I used some bolts or something like that. Any type of spacer will work. I think I ended up using a c/m off an 80 3/4 that has a drop to one side to clear the t-case. Im guessing a different transfer case depends on what spline mine is? Depends what year tranny you are using. The early ones, pre 84 maybe? used 10 spline with a coupler sleeve. After 84/85, they went to a 32 spline male. You could swap the input to a 32 on your t-case, then would need an adapter. Or find a 205/adapter from an 85-91 1 ton, and never worry bout it again. Will I need a different (taller) transmission tunnel.. Nope, 4wd will have the tall tunnel, just cut a hole for the shifter, and start bangin' gears.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Wow. Thanks for that awesome reply. By any chance do you have pictures of your clutch linkage and how you rigged up the clutch pedal?
you will need to get the pedal hanger from a clutch truck, the entire hanger, witch means yanking the steering colomb down, the brake booster off and the same again for yours. you can make yours work but you will still have to pull it to do the work.
wait so you are saying to pull the pedal hanger i have to remove the steering column and brake booster. And that if i cant get a pedal hanger from a clutch truck then i could just modify mine to work
yes, but you will have to pull yours to be able to do the work in the first place.
Alright. I guess I didnt look very close. I found a modification right up that might just prevent this extra work. It looked pretty straight forward with drilling a hole and cutting a notch... I need to get the parts together first though. Thanks for the input.
I used a hydro setup, and did NOT remove the booster. Changing the column and pedals isn't that hard. Biggest pain I found was drilling the pushrod hole in the firewall in the right location. There is sorta dimple marks, but they didn't line up very well.
when i did i kept the auto column so i could fool my stepmom
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s |
Still plays with trucks
Which Washington are you from? Don't laugh I got that question a lot in the military. When you say you are from Washington many people assume DC not the state.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 12-22-2009 at 08:58 PM. |
When I was in the military and told people I was from New York, they automatically assumed New York City. I tell them no, the state, then they say oh you mean upstate New York!! Well almost ALL of New York is upstate of the city!!!! some people....
I was just going to leave the auto column but pull the shifter off. I gotta tear my air tubing crap out before i can really tell whats going on up around the pedal mounts. I figured I'd just go with a mechanical (? linkage) clutch because it would be cheaper and easier to hook up maybe? I guess that depends if i find a donor truck with all the crap on it together.. I cant go forward much more until I can round up parts which will be after christmas
![]() Im in the desert washington ![]() ![]() |
#13 |
Desert is right. This time last year we had four feet of snow on the ground. Right now the ground is bare. No white Christmas for us this year
![]() The reason I ask where in Washington is because my truck is an SM465/NP205 with Dana-44 front and 14-bolt rear and I am going to convert it to an automatic in the spring so my truck could be a pretty good donor vehicle for you. I assume you have 10-bolts front & rear and an NP208 transfer case. Am I right? You will probably need some conversion U-joints and if your truck is a short bed you will have to shorten the rear driveshaft but that is it. PM me and we can try to work something out if you are close enough.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#14 |
I've done that swap feel free to send me an email and I'll go over all the details. I don't have time right now to post up all the info...work is keeping me busy. rcbildr@hotmail.com
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
#15 | |
