Old 12-20-2009, 07:38 PM   #1
srea76
srea76's Avatar
rust repair suggestions?
I am posting pictures below of the rust on my drip rail above both doors bad, and minor stuff around entire thing. To the point where it leaks inside some and there is a bit of bubbling starting to happen inside. I am curious if others have tackled anything like this before. I would like to order one of the out shells for the cab, but not sure I can get rid of all the rust that way? Maybe if I cut the top off and wash it down with ozcoat, even into the cab arms. Anyway what would others suggest?
srea76 is offline   Reply With Quote
Old 12-20-2009, 07:51 PM   #2
cdowns
cdowns's Avatar
Re: rust repair suggestions?
me i'd get a new cab
Old 12-20-2009, 08:07 PM   #3
srea76
srea76's Avatar
And that may happen, but other than the drip rail the cab has no issues. Rocker panels, cab corners, everything is perfect except drip rail. Plus the funds for a whole new cab are short to come by.
Old 12-20-2009, 08:38 PM   #4
joe b
find a roof and pillers off a rusted cab
joe b is offline   Reply With Quote
Old 12-20-2009, 11:02 PM   #5
71 super
71 super's Avatar
I agree with cdowns, you need another cab, that is going to get worse not better. You could always cut the top off another but do you really want to do that? A solid cab would be the easiest, least time consuming and overall best in the long run. JMO
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-20-2009, 11:14 PM   #6
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I posted the same thing today in the Paint/body section.
http://67-72chevytrucks.com/vboard/s...d.php?t=377183
Not looking good for ether of our cabs. I've started looking for parts trucks
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-21-2009, 12:22 AM   #7
kev2809
low n' slo
kev2809's Avatar
if your cab is good and you got the time and the skill, I would cut the top off and put a good one on. its probably gonna be more labor, but your labor is free (at least that's the way I look at it on my stuff). unless you can find a good cheap cab..maybe you can make one good one out of 2.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
