01-24-2003, 03:08 PM | #1 |
Wrench For Lower Control Arm Bushing
Can someone tell me what size wrench or socket to get for the lower control are bushing caps?
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
01-24-2003, 03:13 PM | #2 |
Huge ! I just used a pipe wrench. Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-24-2003, 03:20 PM | #3 |
Thats my back up plan....
01-24-2003, 03:33 PM | #4 |
Fabricate till you "puke"
ive got 1 5/8"....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-24-2003, 03:41 PM | #5 |
Almost Satisfied
I think crazy has got it. I went to Sears and picked up a socket for around $20 to do mine. Pipe wrench will leave "scars"
I took an old cap in with me to the store to make sure I had the right size socket.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-24-2003, 04:07 PM | #6 |
Yea,I cheated....... I walked out to the garage, & slipped a socket on the lower bushing! the thought of bustin a knuckle with a pipe wrench is still in my memory(ouch, done that) crazyL
01-24-2003, 04:10 PM | #7 |
17.00 dollars at Sears part number 947783000 1-5/8 socket For any body planing on doing any front end work, the top control arm bushing caps use a 1 3/8 socket
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas Last edited by Frank_Zeller; 01-24-2003 at 04:15 PM. |
01-24-2003, 04:19 PM | #8 |
Now the post comes in, LOL. I looked for several days before I came up with the right sizes. I measured at 1/16 over the actuals, but that was probably dirt and grease.
1 5/8 and 1 3/8 are correct. Now can someone explain how to put this back together and get the correct measurements. |
01-24-2003, 04:39 PM | #9 |
The uppers are easy. Screw one cap in until it bottoms, then screw the shaft in until it bottoms, then turn shaft back 1/2 turn then screw the other cap on until it bottoms. This method gave me about equal spacing on both sides.
Not sure if this is right but it worked.
01-24-2003, 07:31 PM | #10 |
we used to have boats and i got sockets in the basement from 1''-3 3/4 also one 5'' socket the ratchet is like 50-60 lbs, too bad i cant ever use em.
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
01-24-2003, 07:47 PM | #11 |
Yeah, when I did mine I decided to invest in some 3/4" drive stuff. The 3/4" breaker kicks butt, but it costs a lot to get all of those sockets.
Make sure to get a male-3/4"-to-female-1/2" adapter for torquing.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
01-24-2003, 08:04 PM | #12 |
I used a flat Jaw pip wrench no damage to the paint And I figure I got about 80 ftlbs.
