Old 01-24-2003, 03:10 PM   #1
gman
Polyeurethane vs. Rubber mounts/bushing
Looking for opinions as to which way to go. Advantages vs disadvantages of each. Looking to start replacing cab mounts, radiator mounts, transfer case mounts and just not sure which way to go. Don't want to stiffen the ride up anymore than already and new lift is in the plans soon too. If I go poly they will all be black......no flashy colors on the chassis for me. Sorry.....I like stock look. Anyone have experience with brand new rubber vs. poly? Which way should I go?
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 01-24-2003, 03:31 PM   #2
Stout72
Not my good side.
Stout72's Avatar
I'd be interested in hearing other's opinions as well. Ditto what gman is looking for, but I'm interested in those for the leaf springs & sway bars as well.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 01-24-2003, 03:43 PM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
this has been discussed several times on the board and from what I can tell the rubber is the winner when it comes to cab, radiator support mounts. Poly is good in sway bar, trailering arms etc. Everywhere else rubber. The rubber will flex more and not transfer the jar that the poly will. I'm sure all the opinions will be posted again.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-24-2003, 03:51 PM   #4
Charlie Coleman
Charlie Coleman's Avatar
I'm with 1971Stepside. You will feel the Poly.
Charlie Coleman is offline   Reply With Quote
Old 01-24-2003, 03:51 PM   #5
gman
1971stepside,
Sorry for the repetitious question.
Old 01-24-2003, 04:52 PM   #6
smokekiki
Mike
smokekiki's Avatar
On my lifted blazer I used all poly,susp. and body.It gives a firm ride.I feel the blazer handles better with the poly.As far as the ride and noise,the blazer is LOUD and rough ride either way.My sub has poly in the suspension and new rubber body mounts.The new mounts make it ride nice.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-24-2003, 05:04 PM   #7
1971Stepside
Almost Satisfied
heck gman don't be sorry that what this board is for. I know I have asked questions that have been covered before....
Old 01-24-2003, 05:40 PM   #8
COBALT
COBALT's Avatar
Based on my experience it depends on application. Since this has already been mentioned I'll keep this post short.
Wherever you need yield or flex use rubber. Wherever you need something stiffer use poly.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 01-24-2003, 05:49 PM   #9
crazy longhorn
Fabricate till you "puke"
Poly for suspension, & rubber for the body.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-24-2003, 07:52 PM   #10
71k5
My vote goes with crazy L...
71k5 is offline   Reply With Quote
Old 01-24-2003, 10:48 PM   #11
RShaips
I just removed my cab from my 67 2WD today and I am going to put it on my 72 4wd,I was going to use rubber mounts ,my question is should I buy the mount kit for a 4Wd or 2wd,I think I need the 4wd mount kit sunce that is what it is going on,also I need to cut my floor out and install a high hump for the transfer case shifter,how big a hole do I really need to cut out.I have a high hump cover to install but really don't think I need to cut the complete size of the cover out. Thanks
RShaips is offline   Reply With Quote
Old 01-25-2003, 12:40 AM   #12
Sierra
I replaced all body-to-frame mounts and front sway bar and front suspension components with polyurethane bushings. My overall impression is that the truck now handles MUCH better, and the ride is as comfortable as before. If you are concerned about ride stiffness, rest assured that poly bushings alone will not add to your discomfort!
Sierra is offline   Reply With Quote
Old 01-25-2003, 02:44 AM   #13
BUXMAN66
go bucks!
the one problem w/ poly bushings is that the added stiffness puts more pressure/stress on the surrounding metal and will weaken the floorpans or core support structure.just think,it took 30+ years to break the rubber down,think it'll last you another 30?...... probably! jmo.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 01-25-2003, 02:45 AM   #14
BUXMAN66
go bucks!
Old 01-26-2003, 08:34 PM   #15
ckhd
ckhd's Avatar
I wouldn't think it would be bad to use poly body mounts in a street machine, but I notice your sig says "K10". When you're out 'wheelin, then you subject the pickup to a lot more flex than one that just cruises the streets and goes over a speed bump or two now and then.
Poly doesn't flex. When you have your frame flexed to it limits as you are driving over something while using four-wheel-drive, then poly may bend something. Rubber will give a little and help absorb some of the stress that you are subjecting the body to.
I would use poly in all suspension applications. In fact, I'm going to completely rebuild the suspension in the burb here in a few weeks, and I'm using poly anywhere I can find a poly part for.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
