Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-20-2009, 11:33 PM   #1
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Question What Are These and What Are They For?
Hey guys, I was going through a box of electronic bits and pieces that someone was throwing out and found these. I am wondering, what are they and what are they for? And are they something I could use, if so how does one hook them up?
Benjamin.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 12-21-2009, 01:22 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: What Are These and What Are They For?
Looks like the peices to hook up a amp with. Most factory radio's don't have the RCA hookups in the back of the radio so you have to buy those to turn them into RCA jacks for the Amps. I think thats what they are anyway!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-21-2009, 05:20 AM   #3
mrmischief
Yep. You wire them into your speaker wires and it turns them into rca outputs. How many wires come out of them?
mrmischief is offline   Reply With Quote
Old 12-21-2009, 10:52 AM   #4
Scootin 81 C20
3/4 Ton Rodder
There are 3 pairs of 2. 2 white, 2 gray, and 2 brown.
Old 12-22-2009, 07:43 PM   #5
Scootin 81 C20
3/4 Ton Rodder
Anybody know how to wire them up??????
Old 12-23-2009, 05:20 AM   #6
dammitmitchell
the pollock
dammitmitchell's Avatar
yeap pull the model number off that box dude and google it etc,
simply put positiveand negative white to one speaker.. and the other color to the other speaker, the browns are typically grounds
BUT double check so
search for the company's electircal diagram, and then use T-clips so you dont destroy the harness
and those have adjustable "gain" dials in them.. set them at 3/4 not full.. when "full" on position they give a dirty signal that can ruin your components
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-19-2010, 07:38 PM   #7
TheSunDanceKid
TheSunDanceKid's Avatar
there usally only used if you are going to do an aftermarket amp to either a stereo that is stock and doesnt have rca outputs or a aftermarket stereo that only has one or a few old base models didnt have rca outputs if you arnt using them for either of these things its pretty much useless its not going to improove your sound or anything it will simply do nothing
gray is positive front or rear right speaker
gray/black stripe is negative front or rear right speaker
white is positive front or rear left speaker
white/black stripe negative front or rear left speaker
brown is ground to eliminate alternator whine and other interferance noises
the nobs on the other side are for adjustments
TheSunDanceKid is offline   Reply With Quote
Old 01-20-2010, 02:41 PM   #8
Scootin 81 C20
3/4 Ton Rodder
Ah. I'm not planning on using them cause my sound is good but I may run a single sub on my Sony Xplod deck. Thanks for the info though.
Old 01-25-2010, 06:35 PM   #9
TheSunDanceKid
if your sony has rca pre outs already built on to the back id use those these some times sounds ok but your built in ones are going to get alot better sound with no interfernce
